Cup Holder Problem
Old Jun 19, 2011 | 08:02 AM
ScooterP's Avatar
ScooterP is just really niceScooterP is just really niceScooterP is just really niceScooterP is just really nice
Cup Holder Problem
I am on my second 2007 997 and I have had the same problem in both of them. My C4S cupholder latch would not always go back and latch and i had to have it replaced under warranty because the catch mechanism was failing. Sold the car and got the GT3, but now it is doing the same thing. Has anyone else had this problem? I know it's a small thing, but just curious if anyone else has had the same problem Two cars seems a little bit like there may be a problem with these things.
As always, thanks for the feedback.
Old Jun 19, 2011 | 12:38 PM
JTaylorGT's Avatar
JTaylorGT has a spectacular aura aboutJTaylorGT has a spectacular aura about
Ah yes, one of my main frustrations with my '05 997S (admittedly this is a minor thing but frustrating nonetheless). It's gotten so bad I try to avoid using the cup holders at all because I'm afraid I'll never be able to snap the trim strip back in place!
My car is out of warranty, and the dealer just wants to replace the cup holder assembly (big $$$), so I'm just living with it but have found some tricks that seem to work.
1) If you extend the right side (closest to passenger door) cup holder and feel the side of the small black block between the two cup holders, you will notice a little pin that slides up and down. If you slide it all the way in the up position, and then try to close everything I seem to have better luck. Don't know exactly why!?!
2) I noticed the trim strip that runs across the length of the assembly has a slight play left/right. Try shifting it to the extreme left/right as you flip it up to click in place. I think the problem is because the trim piece shifts to one side and doesn't catch the latch to click in.
Hope that helps.
Old Jun 19, 2011 | 01:48 PM
IslandS62's Avatar
IslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of light
Ive had no problems yet but is this caused by overloading with heavy drinks, or some other cause? I dont use tbe holders often.
Old Jun 19, 2011 | 03:43 PM
ScooterP's Avatar
Not sure what is causing it, but it could be that the drinks are pulling it out of alignment somehow.
Old Jun 19, 2011 | 04:56 PM
jhbrennan's Avatar
I never use it - too many horror stories about spills and sloshes getting into the PCM.
Old Jun 19, 2011 | 09:52 PM
Ynot's Avatar
Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !
Same here, it's not a problem if you don't use it.
Old Apr 8, 2012 | 06:11 PM
MrLister's Avatar
MrLister is infamous around these parts
failed cup holder door touch latch
I bought a 2008, C4S about a year ago. After a few weeks with the car the touch latch on the cup holder door broke. I pulled it from the car and disassembled it to find a small plastic part had broken. The part that holds the door closed. To my dismay Porsche does not sell the internal parts,.. just the whole assembly. Can't see paying $200 or more for a $0.35 part. There has to be a sourcce for this part, but I cant find a thing on the internet. Does anyone have a resource where I might find the correct part?
Old Apr 8, 2012 | 06:52 PM
chudso's Avatar
chudso is infamous around these parts
I've had my cup holder replaced twice, under warrantee, in less than 6 months.
Old Apr 8, 2012 | 07:31 PM
MrLister's Avatar
It's frustrating. Such a small thing, but you want the car to be whole and done right,... without spending a lot.
Old Apr 8, 2012 | 08:12 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
I can't believe a GT3 has a cup holder. My Boxster's did but not my Carrera.
Old Apr 8, 2012 | 08:47 PM
Alan C.'s Avatar
Alan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond repute
I'm surprised they put one in the GT3
Old Apr 9, 2012 | 02:00 PM
Minok's Avatar
Minok has a spectacular aura aboutMinok has a spectacular aura about
Its precisely for this niggly little stuff that 3d printers are such a great thing.. and the home versions are getting cheaper and cheaper with things like makerbot. One can get a 3d printer for benchtop use and print out a nylon replacement part, if you can get the original modeled in the computer. So someone with a printer, access to a laser 3d scanner and the desire, could make a decent business out of printing and delivering replacement parts for $30.
If someone doesn't start such a business soon, I may have to get into the fray.
Old Feb 12, 2015 | 09:57 PM
thackl's Avatar
thackl is a name known to allthackl is a name known to allthackl is a name known to allthackl is a name known to allthackl is a name known to allthackl is a name known to all
Hope that helps.
Sorry to resurrect an old thread. I've been using my cup holders regularly for 4 yrs and never an issue until this morning. Neither of the above tricks worked. Maybe somebody could start me right direction for removing the assembly?
Old Feb 13, 2015 | 06:27 AM
FlaHeel's Avatar
Use the cup holder that was in the 1980s-1998ish Carrera's, BETWEEN YOUR LEGS!
Old Feb 13, 2015 | 07:12 AM
thackl's Avatar
Only if it's McDonald's coffee
