will the Dectane LED DRL fit this Front End?
1 Attachment(s)
Does anyone know if the Dectane LED DRL's will fit on the front end of my 06 C4s?
My bumper is aftermarket (GT2?) and if so, can I confirm that the Dectane LED DRL's are Plug n Play? I understand that I will need to buy a module to get them to work as true DRLs Merry Xmas! |
Yes I think it will fit on that front end and yes it's plug and play.
If your current bumper accepts stock DRL's then I would expect the LED aftermarket versions to fit just fine.
Our DRL will fit your Rinspeed front bumper. We have new shipment coming in by end of Jan. Since you're local, you can drop by to our shop at Richmond and try the sample first. Please email me at info@rotteccarbon.com to arrange!
Stock DRLs
That was the gist of what i was asking as I was unsure if my bumper, which Ray kindly pointed out is Rinspeed which I did not Know, has stock DRLs like a normal 2006 C4s or if the aftermarket bumper contained aftermarket DRLs that were not the same fit as the stock DRLs
So I assume if Rays Rotec LED DRLs fit then the bumper has the stock fit DRLs and the Dectanes will also fit.(and in order to use the Dectanes as normal DRLs I would need the module installed also, otherwise I would have to manually activate the Dectanes each time I drove in the daytime, which I don't want to do) |
