Cabriolet top marks and a few rattles
My new-to-me 06 cab (34k miles) has some white fade marks on the top, looks like some slight wear from folding. It also has some circles on it that I have seen on other 997 cabs, they must be from the top structure. Are there any products out there to rejuvenate the fabric? Can anyone recommend a great detailer in the Boston area?
There are also some rattles from either the top or the rear windows, are there any TSBs about those that I might be able to point out to the service advisor at the Porsche dealership? The headliner is bunching at the rear corners with the top up, so they will be getting into it for that anyway. It's a CPO car, not sure whether rattles would be covered under CPO, but since I just bought it they will probably at least look into it for me.
Thanks!
Thanks!
I have a 06 C2S cab. My top is navy blue, and I cleaned and dyed it a few months ago, which helped to even out the color. I'll need to dig out the receipt for the products I used and where I got them. Those circular marks are from the pads that rest against the top in the stowed position.
I have a rattle over the driver window, coming from somewhere in the roof mechanism. Initially the sound seems to be coming from the door panel, but when I move my head over to that area, it is definitely coming from the top, not the door. I've inquired at dealer and they've never had any luck finding it. I was also told it wouldn't be covered under CPO unless a defective part was involved. I have found that if I put the roof down and then up again, the sound disappears for a while. Sometimes, while at a stop light, I'll just release the roof for a foot or so, then put it back up, and it cures the rattle for a while. I have felt up in there and tightened torx screws in the frame etc, but have never found the specific cause. Let me know if you ever find it.
regarding the noise, you may want to check the cross bow that is on top of the headliner. sometimes they rattle with bumps or wind. they need to be hot glued together. if you get squeaking where the header meets the top, it would be lubricating the header or a flocking panel is warped.
as far as the marks, is that where there is wrinkling, typically at the c pillar? if so, keeping the top up when not driving will help to smooth it out. spraying the top protectant after cleaning the top will also make the top more durable and slightly darker. i use the protectant every year but 6 month is better if you park under the sun or drive in rain a lot.
check the the two Torx bolts (t-30) on both sides of top
see pics (na011)
also (per na011)
Also try lubing the joints with "DuPont Multi-Use Dry, Wax Lubricant". You can buy this at Lowe's.
http://www.webbikeworld.com/t2/motor...n-chain-saver/
Use 303 Aerospace Protectant on all the rubber parts. The 303 is a great product. I use it on all vinyl, rubber & leather. The 303 High Tech Fabric Guard is good for your top. Both protect from UV rays.
http://www.303products.com/shop303/i...fm?category=58
see pics (na011)
also (per na011)
My light rattle definitely isn't the torx bolts, and isn't rubber seals. It is something more like a piece of plastic rattling/vibrating against the inside of the top.
sometimes they are loose and it sounds like its coming from the roof.
Thanks for the tips. I'm wondering if mine might not be the driver's seatbelt reel. I have to investigate a little bit more. But if they replace the headliner, as I hope they will, or at least remove it, I would guess that would be a good time to have them tighten and lube everything in the mechanism.
Great pics to show the bolts, thanks!
I've checked them. My noise is definitely coming from directly above the driver's window next to my left ear. It is there regardless of whether or not the window is up or down. But is totally gone when the top is down, and doesn't come back right away after the top is put up. But it typically returns after a few miles.
Mine seems to have the same problem, I think it's the plastic? cover that goes across the width of the top. I can feel it through the headliner, it feels like a u-shape piece that wraps around a metel piece that goes across - if I am making any sense.
I'm curious, as well. Is this the dye you used?
http://store.carcareonline.com/renov...terbottle.aspx
Wheel Experts
09-02-2015 09:04 AM
Wheel Experts
Wheels/Tires
09-02-2015 09:02 AM
