Quick question about stock brakes
Old Jun 23, 2012 | 02:13 PM
metzkaro's Avatar
metzkaro is infamous around these parts
I have a 2007 Carrera S with stock brakes. When I drive most of the time it makes that screechy sound when im hitting the brakes. I've had them checked and was told that my brakes are still in great condition. What can I do to get rid of this sound?
Old Jun 23, 2012 | 07:01 PM
randysmithla's Avatar
randysmithla is infamous around these parts
happens all the time to me. it usually goes away after i wash the car..and back in a few days. still have lots of life left too
Old Jun 23, 2012 | 10:06 PM
Tcc1999's Avatar
Tcc1999 is a splendid one to beholdTcc1999 is a splendid one to beholdTcc1999 is a splendid one to beholdTcc1999 is a splendid one to beholdTcc1999 is a splendid one to beholdTcc1999 is a splendid one to behold
Do you mean like a high pitched squeal or squeak? I don't know if it is the same situation but I had a squeal on my old '08S and was told it was due to the fact that when you drive around town the brake pads basically develop a glaze on them due to gentle braking. They still work fine but the squeal that you hear is basically vibration probably because the pads are not gripping 100 percent. Apply the brakes hard (not panic stop but firm pressure to slow quickly, or go to the track for a DE) and that might do the trick. For the record on my old 911 the squeal would also go away after washing. Once I started to exercise the brakes/pads the squeal went away.
Someone please correct me if I have erred anywhere in the above. (Similarly, for what it is worth, I get nasty squeal on bicycle brake pads/rims when I use regular pads with carbon fiber rims. After a ride, the pads are not grippy at all and have a smooth glazed texture. They still work but you need to apply more pressure compared to using a proper pad/rim combination.)
Old Jun 23, 2012 | 11:21 PM
Super Adjuster's Avatar
Super Adjuster has a spectacular aura aboutSuper Adjuster has a spectacular aura about
Try some strong braking from 60-5 mph a few times. That might "re-bed" the brakes.
Old Jun 24, 2012 | 09:32 AM
semicycler's Avatar
semicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond reputesemicycler has a reputation beyond repute
Anyone try swapping brake pads with low dusting aftermarkets, like EBC Red Stuff or Hawk ceramics? It's worked for me on other cars.
Old Jun 25, 2012 | 10:02 AM
Johnny DB's Avatar
I never get the squeal as I always do a few hard stops when I drive. My friends car squeal's all the time but he brakes like an old granny...
Old Jun 27, 2012 | 11:02 AM
spiffyjiff's Avatar
spiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud of
yep, pad glaze. try some hard stopping in succession. if that doesnt work, you can try flipping the pads inner/outer or left to right, or you can try replacing the noise dampers. all easy DIY's. from what i've seen and read, most folks can get rid of the noise but a few seem to have persistent annoyance.
Old Jul 19, 2012 | 10:59 AM
artyve's Avatar
artyve is infamous around these parts
What are these "noise dampers"? Does anyone have a pic of them? I have a squeal under soft braking in the rear left brake. Starts up after the brakes warm up a bit. Pads look like they still have significant life left.
Old Jul 19, 2012 | 11:15 AM
spiffyjiff's Avatar
i dont have a pic but theyre easy to find if you take out brake pads - they are in betw the pads and calipers. each rear caliper has 4 pucks, 2 on each side of the rotor. the fronts have 1 on each side of the rotor and it is a sort of thin metal plate that has small cylinders attached which fit into the caliper. believe me, easy to see if you take out the pads.
Old Jul 19, 2012 | 11:17 AM
spiffyjiff's Avatar
Old Jul 19, 2012 | 11:38 AM
artyve's Avatar
Thanks for the info. I assume that stock brakes should come with these dampers? And these dampers are supposed to prevent or minimize squealing when brakes are applied?
I talked to my porsche rep who - as expected - said that these are performance brakes and some squealing is expected. Not sure if I should press him further.
Old Jul 19, 2012 | 11:59 AM
amge63's Avatar
amge63 has a reputation beyond reputeamge63 has a reputation beyond reputeamge63 has a reputation beyond reputeamge63 has a reputation beyond reputeamge63 has a reputation beyond reputeamge63 has a reputation beyond reputeamge63 has a reputation beyond reputeamge63 has a reputation beyond reputeamge63 has a reputation beyond reputeamge63 has a reputation beyond reputeamge63 has a reputation beyond repute
Hey, I brake like a grandpa! +1 on squealing brakes, +1 on Pad Glaze. +1 on going away after a wash or hard braking. I just put up with it now knowing I don't need to unnecessarily wear down my pads just to make the noise go away. The idiosyncrasies we learn to put up with in a p-car.
COBB Tuning
Jan 1, 2025 09:02 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
km90265
Aug 31, 2015 11:00 AM
OldBoldPilot
Aug 24, 2015 04:00 PM
Vrseis
Aug 20, 2015 07:41 AM
