Rim Rash problem..........
Old Mar 10, 2013 | 04:05 PM
Franky Knuckles's Avatar
Franky Knuckles is infamous around these parts
Took a corner too tight last night and scraped my rim. Have any of you guys had this issue before and what did you do about it? I noticed this morning there were some DIY solutions but wanted to know if anybody here had any experiences they could speak on.
Old Mar 10, 2013 | 04:19 PM
awcayenne's Avatar
awcayenne is a jewel in the roughawcayenne is a jewel in the roughawcayenne is a jewel in the rough
i called one of those mobile ding doctors which came to my work and took care of it. Couldn't even tell where the rash was after.
Old Mar 10, 2013 | 04:22 PM
killacam's Avatar
killacam Is a GOD !killacam Is a GOD !killacam Is a GOD !killacam Is a GOD !killacam Is a GOD !killacam Is a GOD !killacam Is a GOD !killacam Is a GOD !killacam Is a GOD !killacam Is a GOD !killacam Is a GOD !
get it refinished. should be less than $75.
Old Mar 10, 2013 | 05:29 PM
808c2s's Avatar
808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !
Alloy Wheels Repair Specialist, if there's a franchise in your area. When I nicked/curbed my Kinesis rim, I went to this franchise and the work was flawless. You could also DIY by sanding down the damaged area and try to blend the area with color matched paint from a hobby store. That's what I did to my Supperlegera rim on my prior Audi S4. It was decent but not as perfect as those rim repair specialty shop .
Old Mar 10, 2013 | 05:43 PM
jhbrennan's Avatar
I also used an Alloy Wheel repair specialist and was extremely pleased...but understand that they are franchisees so quality of work may vary. Check with your local Porsche dealer to see who they use.
Old Mar 10, 2013 | 06:47 PM
Cool suggestions guys. Sweet.
Old Mar 10, 2013 | 07:22 PM
cairo94507's Avatar
cairo94507 is a jewel in the roughcairo94507 is a jewel in the roughcairo94507 is a jewel in the rough
Do yourself a favor and have it repaired by a professional in a shop. I would be leery of someone who drives up and claims to be able to fix it on the spot. A professional repair should be about $125.
Old Mar 10, 2013 | 08:24 PM
krysFly's Avatar
krysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant future
just because someone (or a company) drives up, doest mean they are not professional. I have used a "mobile unit" in the past. Very quick, professional, excellent job, less then $100.
Old Mar 11, 2013 | 12:27 AM
808c2s's Avatar
Good point. Coincidentally, my Porsche dealership also uses the Franchise.
808c2s's Avatar
Agreed
Old Mar 12, 2013 | 03:44 PM
Dadio's Avatar
Dadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond repute
Scrapped your rim or scrapped and bent your rim ? If you hit a curb you bent the rim it will need to be removed from the car and the tire removed from the rim to properly fix the damage. The bent rim needs to be heated to properly reshape it. While they can handle a cosmetic repair I don't think the mobil guy can handle a bent rim . I'd take it to a shop that specializes in wheel repair. These wheels very easily bent but luckly very easily repaired.
Old Mar 12, 2013 | 05:36 PM
cairo94507's Avatar
Of course you are right if they pull up in their company truck and have all of the proper equipment. I have seen people doing this type of work at car lots working out of their trunk and the end result looks just like they worked out of their trunk.
Old Mar 14, 2013 | 08:06 AM
LambOfGod's Avatar
LambOfGod is infamous around these partsLambOfGod is infamous around these partsLambOfGod is infamous around these parts
Do you have a photo of your car and wheels. They look chrome in your avatar photo. I'm looking for something similar for my red 911. Any idea of the weights?
Old Mar 14, 2013 | 09:36 AM
awcayenne's Avatar
I had my carrera classic rim repaired by the mobile guys and I couldn't even tell where the rash was afterwards. Perfect color match. And I'm very critical. The best thing is they came to me at work.
Old Mar 14, 2013 | 10:54 AM
808c2s's Avatar
Check my album. They are approx 19 lbs front and 22-23 lbs rear.
silversrt
Jan 24, 2016 03:45 PM
ccjimmyb
Oct 10, 2015 09:47 AM
Oscar 987
Sep 29, 2015 04:57 PM
manfred@loma_wheels
Audi
Sep 26, 2015 07:49 AM
