Engine compartment fan
Old Feb 24, 2014 | 08:22 PM
DOCTOR 911s's Avatar
DOCTOR 911s is infamous around these parts
Does anybody knows how I can switch on the engine fan for better cooling at the engine bay?
I have a 997s cabriolet supercharged and I want to cool the engine bay for more safety and cooler temperatures at track days in the summer
Thanks in advance
Old Feb 24, 2014 | 09:11 PM
808c2s's Avatar
808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !
Old Feb 24, 2014 | 09:21 PM
Originally Posted by 808c2s
After this mod the fan will works and just like before?
I'm ask upping because I know that this engine fan is to take out the hot air from the engine bay.
Old Feb 24, 2014 | 09:24 PM
808c2s's Avatar
Yes. When the switch is off, the fan will function like before. With the switch on, it will run continuously, lowering your engine temp by at least 20F over ambient temp, according to 1999Porsche911.
Old Feb 24, 2014 | 09:27 PM
Now,before the mod how it,works and it will works after?
Is there any problem for the fun if it's works continues with the switch on?
Old Feb 24, 2014 | 09:48 PM
808c2s's Avatar
Before the mod, the fan will turn on only at a certain Intake Air Temp (IAT). By then, the IAT is suboptimal for consistent power output (ie: heat soak). After the mod, it will function the same way, unless you manually turn on the switch for the fan to run continuously. The advantage to running the fan continuously is that the IAT will be lower consistently, thus producing power more consistently.
Only problem I see is if the fan runs continuously, eventually parts will wear out. But, remember, this mod works best in stop and go traffic and on hot summer days, thus you are not really running it all the time.
Old Feb 24, 2014 | 09:55 PM
Before the mod, the fan will turn on only at a certain Intake Air Temp (IAT). By then, the IAT is suboptimal for consistent power output (ie: heat soak). After the mod, it will function the same way, unless you manually turn on the switch for the fan to run continuously. The advantage to running the fan continuously is that the IAT will be lower consistently, thus producing power more consistently. Only problem I see is if the fan runs continuously, eventually parts will wear out. But, remember, this mod works best in stop and go traffic and on hot summer days, thus you are not really running it all the time.
Thank you very much for your help...
Old Feb 24, 2014 | 09:57 PM
808c2s's Avatar
No problem
Old Feb 24, 2014 | 10:01 PM
No problem
And something else.
You propose me to mod and the engine compartment fan and the radiator fan for better cooling?
By the way,I just put evans coolant 180 at the water cooler system
Old Feb 24, 2014 | 10:05 PM
Jam996's Avatar
Jam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud of
Just make sure about which relay to connect to since he did this mod on a 996.
Old Feb 24, 2014 | 10:06 PM
And something else. You propose me to mod and the engine compartment fan and the radiator fan for better cooling? By the way,I just put evans coolant 180 at the water cooler system
What's your opinion for this rear wing?
Is it better for the mod that you told me.
Old Feb 24, 2014 | 10:07 PM
Old Feb 24, 2014 | 10:13 PM
Attachment 338971
Attachment 338972
Attachment 338973
Old Feb 24, 2014 | 10:14 PM
Old Feb 24, 2014 | 11:22 PM
808c2s's Avatar
Ideally, you should do both mods to maximize IAT cooling and engine coolant cooling, but try the engine fan mod first to see if you're satisfied.
And something else.
