Odd TPC Issue
Old Jun 24, 2015 | 03:16 PM
TheInfamousDrew's Avatar
TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !TheInfamousDrew Is a GOD !
Question Odd TPC Issue
For the past few days I've had an odd issue with the TPMS system in my 2007 Turbo.
On random occasions, the TPC system would give an alert that a tire was -4.
When checking the actual pressure using the on-board system and an analog gauge, the pressures would all be correct.
I would go in to the system and reset it and all would be fine.
This has happened about 6 times over the past four days.
The odd thing is, its a different tire each time!!!
Any ideas?
Drew
:::::Update:::::
On Friday, I let out about 10 psi per tire and re-inflated to the original pressure and the issue has not returned.
Old Jun 24, 2015 | 03:43 PM
crazycarlitos's Avatar
crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !
yeah. prob time for new sensors
the TPMS battery lasts 5-6 years before acting weird. How old is yours ?
there are cheaper alternatives to OEM
Old Jun 24, 2015 | 03:47 PM
Oh yea, forgot to add that.
My TPMS are only about 7 months old.
Old Jun 25, 2015 | 04:59 PM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
Did you go OEM or aftermarket? I forget which aftermarket ones have been know to have issues.
Check to make sure you got the right application on the new ones. There are differences among the 911s, turbos, 4s, etc..
Old Jun 26, 2015 | 05:22 AM
White Rock's Avatar
White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !
Have you checked to see if your system is set to partial or full load?
Old Jun 26, 2015 | 09:25 AM
Originally Posted by HOUSE Motorsports
Just to be sure - did you go with part # 997.606.021.01 ? Also, where did you have the sensors done? I'd suggest taking it back to whoever did them - could be faulty sensors...or incorrect coding, etc.
I used aftermarket ones.
Please keep in mind, these have been working just fine for the past 8 months.
Yes there is a possibility that they have failed.
They work just fine until I shut off the vehicle or sometimes when I turn it on.
Strangely when they error out, it's always -4 psi and on random wheels.
This makes me think there maybe a system issue.
Side note, this week has been extremely hot. Every day had been above 100*
Old Jun 26, 2015 | 10:04 AM
There are a ton of aftermarket sensors on the market, some good - some terrible. If you want to provide some information on what sensors you went with etc - or any sort of background information, that would help. If the pressures were reading fine before you replaced the TPMS sensors with the aftermarket ones, it's highly unlikely that it's a control unit/systems issue. Weather doesn't really effect the sensors in any tangible way.
I believe they were ITM.
They were supplied with a set of wheels from N4S motors.
These have been working just fine without issues since October of 2014.
By now all four sensors have given a random -4 psi fault. This isn't all at once, it's random.
This only happens when I turn off or on the vehicle. Not while driving.
When I reset the system they work just fine until the next random fault.
Old Jun 26, 2015 | 11:33 PM
Miami4me's Avatar
Miami4me has much to be proud ofMiami4me has much to be proud ofMiami4me has much to be proud ofMiami4me has much to be proud ofMiami4me has much to be proud ofMiami4me has much to be proud ofMiami4me has much to be proud ofMiami4me has much to be proud ofMiami4me has much to be proud of
There's also a separate control unit for the sensors. I just learned that after I replaced my 4th one, all OEM. The sensors wouldn't come out of learning mode. I hope to get my car back tomorrow, without any #%$@ errors.
Old Jun 27, 2015 | 04:01 AM
PatrickBateman's Avatar
PatrickBateman is infamous around these parts
I got tired of mine yelling at me...so I just unplugged them, and coded them out. life is good now manually checking them once per week. I remember the president barking at us about checking tires to save gas. this being said, its the only advice ive taken from the poor guy.
Sucks OP. I hate dismounting tires before replacement level to screw with such an annoyance as this system.
Old Jun 27, 2015 | 07:17 AM
North Shore 911's Avatar
North Shore 911 is infamous around these partsNorth Shore 911 is infamous around these parts
I had a feeling they were the Blue ITMs... Hate to break it to you - but those fall into the terrible category. See if the vendor will warranty them since it's been less than a year. If they don't, and you want to replace those ITMs - go with the HUF sensors. We do about 2 sets of TPMS sensors a week here at the shop - our techs have seen em all.
+1 on the HUF sensors. I bought a new set from Titan TPMS for my set of snow tires on my 2010 C4S Cab and they work great. There are a lot of cheap options out there and the HUF sensors weren't the cheapest, but they work great in ridiculous conditions (my C4S is my DD and the Chicago winters can be - and have been - brutal!)
adnanm3
Nov 22, 2023 02:43 AM
proTUNING Freaks
Sep 15, 2015 07:28 AM
GSP
Sep 9, 2015 05:31 AM
falter
964 Turbo
Sep 4, 2015 01:41 PM
falter
964 Turbo
Sep 4, 2015 01:37 PM
