Front Fan Issue
Hi Guys
997 C2 06 I have an issue with the front radiator fans, where they're kicking in about 30 secs after starting the engine and not going off. They both appear to be spinning full blast as they're noisy as hell and both are pushing lots of air in the wheel wells. They both seem to be moving freely with no sign of debris making them stick. I've tried turning AC off but that didn't help. Anyone have any ideas or point me in the direction of sensors to check? Cheers Rob |
Originally Posted by MrX
(Post 4575807)
Hi Guys
997 C2 06 I have an issue with the front radiator fans, where they're kicking in about 30 secs after starting the engine and not going off. They both appear to be spinning full blast as they're noisy as hell and both are pushing lots of air in the wheel wells. They both seem to be moving freely with no sign of debris making them stick. I've tried turning AC off but that didn't help. Anyone have any ideas or point me in the direction of sensors to check? Cheers Rob In your car's case hard to believe both fan ballast resistors went bad at the same time. 'course, this assumes the 997 fans work the same as the older model fans. Regardless it reads like a common failure mode and my advice would be to have the car connected to a Porsche diagnostics computer. The tech can check for any "fan stage" errors and if he finds any this can really shorten the amount of time it takes to nail down what is wrong. |
Thanks, i'll get the codes checked and report back. Cheers
So I have read the fault codes and i get -
P1632 Air Conditioning Control Module - No Communication and AC Fault code 8033 Unknown fault code Does it sound like a plug has come loose? |
(Post 4576357)
Originally Posted by modlin
(Post 4686874)
hi…have a same issue…on my 2009 C2 997.2….what was your fix?
no similar issue on your or 997.2 ? |
Yes, you will have a plug off somewhere - check around the ac rads in the front. Your system will be detecting a "fault" with the ac somewhere and so it defaults the fans to high as a safety/overheating precaution. The fans will be fine.
Has anyone found a solution to this I have the same problem. Currently looking over the car for unplugged sensors.
Originally Posted by myltz400
(Post 4831515)
Yes, just the A/C is not working and front radiator fans on full blast all the time. I also have A/C communication fault.
https://cimg4.ibsrv.net/gimg/www.6sp...96c5dee078.jpg
(Post 4831526)
for my 911 997.2 2009 part no was99657392300 good luck |
Don't know if this is related but my '06 which I purchased new had a recall on the front fans.... I don't recall the issue but might be something to look at
Best, Matt |
Mine turned out to be a fuse.
Thanks to everyone with input! |
Thanks for the update. Need to tend to something similar on mine
(Post 4576357)
P1632 Air Conditioning Control Module - No Communication and AC Fault code 8033 Unknown fault code Does it sound like a plug has come loose? HI i have the exact same faults P1632 /8033 Front fans stuck on full speed. I understood 8033 to be pressure sensor issue so drained the ac charge and replaced the pressure sensor then got a fresh air con charge - no change names faults persisted. Have checked all fuse everything is fine. I am suspecting the module next to the fans behind the right bumper shield, as it looks to be the controller for for the AC pressure sensor. Any help gladly recieved.. thanks Will |
