HRE C21 not drilled for OEM TPMS...help!
Old Jan 21, 2017 | 03:17 PM
tphan's Avatar
tphan has a reputation beyond reputetphan has a reputation beyond reputetphan has a reputation beyond reputetphan has a reputation beyond reputetphan has a reputation beyond reputetphan has a reputation beyond reputetphan has a reputation beyond reputetphan has a reputation beyond reputetphan has a reputation beyond reputetphan has a reputation beyond reputetphan has a reputation beyond repute
Took wheels/tires to shop today to find out the rear wheels aren't provisioned for OEM TPMS...what options do i have, anyone experienced similar issue?
Didn't noticed until today
Thank you.
Old Jan 21, 2017 | 03:41 PM
tphan's Avatar
The brackets solution should work, the strap is way too primitive.
Any input still is appreciated.
Old Jan 22, 2017 | 06:57 AM
jhbrennan's Avatar
Call Dave Martin at Wheel Enhancement - he may have suggestions...maybe drill out the opening?? Did you buy new or used?
Old Jan 22, 2017 | 08:55 AM
tphan's Avatar
Bought used, previous owner had the 3.5" lips replaced new by HRE, his 911 was pre-2007 maybe that's why the valve stem holes are different than the front. The brackets should work with bolt-on 6 mm stems, i will call WE tomorrow.
Thank for the help.
Old Jan 25, 2017 | 10:04 AM
GMP Performance's Avatar
Site Sponsor
I have 3 of these left if you need some!
Old Jan 25, 2017 | 11:58 AM
tphan's Avatar
Thank you but that won't work, TPMS positioned too close to outer bead.
Dave Martin gave 3 options:
1. Enlarge the 6mm valve stem hole
2. Ship wheels to HRE
3. TPMS strap (last resort)
Apparently these wheels are C93 produced before TPMS was mandate...it is odd that the fronts are but not rear.
Old Feb 4, 2017 | 03:59 PM
tphan's Avatar
Update
called couple wheel repair shop, first one don't modify wheel due to liability, second shop estimate $85.00 per wheel (as soon they asked what type of car i know it's cha-ching time).
After some research I decided to do the job myself. With a carbide step drill bit and lot of patience, for $19.95 + 1 hour I did an awesome job.
The bit is bad ***...super clean cut.
Can't wait to get these mounted.
Thank everyone...
Old Feb 4, 2017 | 05:31 PM
Jose911's Avatar
Jose911 is infamous around these parts
I want to see how they look on your car as I too. I feel those wheels look great as well.
Old Mar 9, 2017 | 01:36 PM
tphan's Avatar
got the HREs mounted to tires, the TMPS sat flushed once torque to spec. Wheels are on the car now, no sign of pressure drop in last 4 days. Offset is perfect, rear wheel has 5mm clearance between brake caliper and wheel, that should be fine.
Hope to get some picture this weekend. Can't wait to see what 40 lbs less of unsprung weight do.
