997.1C4S Bad start when warm.
Old 09-12-2018, 02:38 AM
997-Carr4S's Avatar
997-Carr4S is an unknown quantity at this point
Question 997.1C4S Bad start when warm.
Hello I'm new here. I got a 997.1 C4S Tiptronic. Small problem. When cold: engine is running directly after starting. When warm: starting within 10 min; no problem. Starting after more than half an hour(half-warm): I have to use the "gas-pedal" otherwise the engine won't start. After that it runs correctly but there is a lot of "petrolsmel". My P-specialist don't know what the problem is. Who can help ?
Old 09-12-2018, 04:52 PM
Matthew Yonan's Avatar
Matthew Yonan is an unknown quantity at this point
Old 09-13-2018, 05:15 AM
Petza914's Avatar
Petza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond repute
Originally Posted by Matthew Yonan
It doesn't sound like he has a slow crank issue on hot start, but rather the engine turns over but doesn't start. If that's correct, its a different problem than the linked thread and could be many things such as plugs and coils, bad MAF, bad Crank position sensor, bad cam position sensor(s), vacuum leak, etc
Any CEL codes? Does it run and drive fine once you do get it started or does it misfire or sputter?
Old 09-13-2018, 07:48 PM
ENVē's Avatar
ENVē is a jewel in the roughENVē is a jewel in the roughENVē is a jewel in the rough
From what I am reading it is the starter on its way out and possible bad alternator cable
977ttblue
04-28-2016 10:34 PM
alf996
08-07-2008 05:49 AM
ExTex50
05-26-2006 09:30 AM
Quick Reply: 997.1C4S Bad start when warm.
