997 newbi/coolant/auto-x
Old Sep 24, 2007 | 04:28 AM
bhart192's Avatar
bhart192 is infamous around these parts
Question 997 newbi/coolant/auto-x
question: I month old 997s owner 1st time porsche
1) owners manual states coolant is " permanent" is that right never needs
change,level is slighly below Min. mark should I add going to 1St DE in 3
weeks.
2) looking for info on tire pressuer @ Auto X ,running Ps2 's .19" ,used to run
M#
othre than that this car is un f--king real ,came over from BMW M3 .
997 S w X51 thanks Bob
Old Sep 24, 2007 | 07:16 AM
mdrums's Avatar
mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !
I have 9 DE and 1 autoX on my 997S and never had to change or add coolant. For stock 19" wheels start out cold pressures for a autoX at 32 front and 35 rear. Check hot and keep them below 40...38 is really good. For solo group hot laps at a DE start out at 29front and 30 rear for hot summer air/track temps.
Old Sep 24, 2007 | 07:53 AM
LarryP's Avatar
LarryP is a name known to allLarryP is a name known to allLarryP is a name known to allLarryP is a name known to allLarryP is a name known to allLarryP is a name known to all
I have a 06 997,4 autox's never had a coolant problem,But I did need to add oil around a year into owning the car.I only have 5k on the car.
Air ,I put in whatever the porsche says to put in.What you need to do is after your first run look to see if there is wear on the side walls.If not your good if you want more grip lower it a little but after the run always look to see if the side walls a not scuffed.
Paintballzen
Oct 10, 2020 12:22 PM
John@SpeedTech
Sep 4, 2015 07:23 AM
PelicanParts.com
997 Vendor Classifieds
Aug 20, 2015 02:39 PM
PelicanParts.com
997 Turbo Vendor Classifieds
Aug 20, 2015 02:38 PM
