Cadillac CTS-V vs. Modified R1 Motorcycle
I am assuming it is this car -
Build Sheet:
Individual Tuning Components
http://www.youtube.com/watch?v=QfMpsf6gYU8
TJ
Build Sheet:
- D3 Air Intake System
- Genuine K&N Air Filter
- D3 ø102mm Throttle Body w/Spacer
- D3 Methanol Injection System (50/50 Mix)
- D3 Electronic Flow Matched High Flow Fuel Injectors
- Kenne Bell Boost-A-Pump
- MSD Ignition Coil Packs
- MSD Insulated Spark Plug Wires
- D3 Quad Tip Spark Plugs
- D3 XL Front Mount Intercooler with 20Gal/Min Fluid Pump
- D3 ø9.5” Diameter Pulley Kit
- D3 Blanchard Ground Supercharger Lid Spacer
- D3 Ported + Polished Blower Snout
- Solid Isolator Bushing
- Kooks 1 7/8th in. X ø3in. Stainless Steel Headers
- Kooks –X- Pipe w/interface for CORSA Exhaust
- Corsa Sport Exhaust System
- D3 PCM Mapping/Performance Tune
- D3 Transmission Tune/Automatic Shift Calibration
- Front: OEM
- Rear Wheel: Forgeline Ultralight Drag Wheels 11.0” x 18”
- Rear Tire: 305/35/18 Mickey Thompson Drag Radials
TJ
10-02-2015 02:23 PM
ModBargains.com
996 Turbo Vendor Classifieds
10-01-2015 11:48 AM
