Go Back  6SpeedOnline - Porsche Forum and Luxury Car Resource > British > Aston Martin > Aston Martin Vendor Classifieds
Reload this Page >
Forgestar F14 Super Deep, Full Face, and Concave! Many Fitments! Rotary Forged!
Notices
Aston Martin Vendor Classifieds vendor classified area...do not post here unless you are a forum sponsor
Old 04-22-2013, 03:59 PM
Get Your Wheels's Avatar
Get Your Wheels is a splendid one to beholdGet Your Wheels is a splendid one to beholdGet Your Wheels is a splendid one to beholdGet Your Wheels is a splendid one to beholdGet Your Wheels is a splendid one to beholdGet Your Wheels is a splendid one to beholdGet Your Wheels is a splendid one to behold
A modular, full-faced and deep concave wheel that is strong, lightweight and reasonably priced! Fitments for Aston Martin (including the Aston Martin V8 Vantage and other Aston Martins)!
Lots of space for BBK clearance and custom finishes are also available.
Forgestar customizes each wheel and offset based on your order, so you can get the exact fitment you want.
Semi Concave - Almost flat, but it has a subtle concavity to the face. These look great and work great for a classy & OE look and feel.
Deep Concave - Much more aggressive concavity to the face, and very noticeable. Available in 9.5" - 12" wide only.
Super Deep Concave (19" wheel only - extra charge) - Newest concavity. More aggressive concavity than "Deep Concave". *Available in 19"x 9.5 - 12" wide only.
18" Fitments
18" Semi Concave
188.5 offsets from +26 to +50
189.0 offsets from +20 to +55
189.5 offsets from +26 to +60
18" Deep Concave
1810 offsets from +16 to +42
1811 offsets from +23 to +55
1812 offsets from +36 to +68
19" Fitments
19" Semi Concave
19x8.5 offsets from +26 to +48
19x9.0 offsets from +20 to +55
19" Deep Concave
19x9.5 offsets from +4 to +42
19x10 offsets from +20 to +44
19x11 offsets from +23 to +55
19x12 offsets from +36 to +68
19" Super Deep Concave
19x9.5 offsets from -25 to +24
19x10 offsets from -19 to +32
19x11 offsets from -6 to +42
19x12 offsets from +6 to +55
20" Fitments
20" Semi Concave
208.5 offsets from +26 to +50
209.0 offsets from +18 to +56
2010 offsets from +31 to +69
2011 offsets from +48 to +81
20" Deep Concave
209.5 offsets from +7 to +43
2010.5 offsets from +20 to +55
2012 offsets from +39 to +75
Custom Mag Blue Finish Super Deep
Staggered Silver Semi Concave & Super Deep
Custom Gold Finish on a Square Deep Concave Set
Matte Black Super Deep
Deep and Super Deep Staggered
Old 06-02-2013, 10:56 PM
L.A.P.'s Avatar
L.A.P. is a jewel in the roughL.A.P. is a jewel in the roughL.A.P. is a jewel in the roughL.A.P. is a jewel in the rough
Have been seeing a lot of people with Forgestars. Just wondering what construction process is used in their creation. I assume they are cast? Look nice!
Old 06-03-2013, 10:42 AM
Since Forgestar's website is a lot more inclined to answer this question, here is what the technology entails:
"Forgestar's Rotary Forged Flowforming process is a unique solution to a common problem how to make a wheel both light and strong.
This specialized process begins with a low pressure type of casting and uses a special machine that spins the initial casting, heats the outer portion of the casting and then uses steel rollers pressed against the rim area to pull the rim to its final width and shape. The combination of the heat, pressure and spinning create a rim area with the strength similar to a forged wheel. During Flow Forming, the pressure applied to the cast rim actually changes its mechanical properties, so its strength and impact values become similar to those of a forged rim. That translates to up to 15% less weight when compared to a standard cast wheel. The resulting grain structure within the alloy of the wheel is linear, flowing in a single direction.
This grain structure pattern, combined with the exceptional quality of casting required for the process, gives the rim area of the wheel huge mechanical strength, and elongation. As a result of these mechanical characteristics, Forgestar is able to reduce the thickness of the rim area resulting in reduced weight, without compromising strength and resistance to impact."
Essentially, what you get is a wheel in between a traditional cast and a fully forged custom wheel. Flowforming is a lighter and stronger wheel than traditional cast wheels. In addition, you are able to get custom offsets which is a huge, huge plus those wanting an exact with without having to work around using spacers. And they are very, very reasonably priced!
Old 06-03-2013, 05:26 PM
L.A.P.'s Avatar
Makes sense a great option for people with a tighter budget.. Might have to consider a set in the future
Old 06-04-2013, 03:00 PM
Definitely! However, if you are looking for a fully custom/forged wheel, we can help setup a set for you as well. We just finished an ADV.1 wheel which is on the completely opposite in terms of pricing in comparison to Forgestar's.
Old 06-05-2013, 09:09 AM
All PM's replied, thank you!
Old 06-10-2013, 11:06 AM
Monday bump!
Old 06-13-2013, 01:54 PM
Old 06-26-2013, 01:58 PM
Super Deep bump!
Old 08-07-2013, 12:02 PM
Thank you for the continued interest!
Old 08-13-2013, 03:40 PM
Old 08-21-2013, 01:22 PM
Thank you for your continued interest!
Old 08-26-2013, 02:27 PM
All PM's replied, thank you for your continued interest!
Old 08-29-2013, 11:58 AM
PM us for our special Labor Day pricing! Good until Monday!
Old 09-04-2013, 11:43 AM
Jibberingloon will become famous soon enough
Have you got any pictures on a vantage?????
Please post some
Quick Reply: Forgestar F14 Super Deep, Full Face, and Concave! Many Fitments! Rotary Forged!
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
