Break-in Period? / Weird Burnt Smell
Hi fellas,
Can you tell me if there is any "break-in" period that I should be aware of on a 2009 V8 Vantage? I was under the impression that these engines are broken in at the factory.
If there is a break-in period, (i) how long is it in terms of miles and (ii) what should I avoid doing besides driving at constant speeds for prolonged periods of time?
I purchased my car with about 3,200 miles. I hardly get to drive it so whenever I do I pretty much let it loose, occasionaly hitting the redline. A few weeks back, I was driving along and quickly realized that I had just passed a spot that would serve for a good photo op. So, I slammed on the breaks, popped it into reverse (I have a 6-speed manual) and quickly backed up into the side of the road into the right spot. When I turned the engine off, I noticed a burnt smell. I assumed the smell was from the clutch, after having reversed in so quickly and perhaps not releasing the clutch entirely. I wasn't worried as I was only in reverse gear for about 30-40 feet or so.
I have driven a manual transmission all my life and have never experienced that smell...luckily, I have never had to change a clutch in any of my cars to-date.
Is there something about the V8 Vantage and reverse gear? Is it easier to burn the clutch in reverse? Or could that smell have been from a fairly new engine being driven really hard (and hence my question about a break-in period)? Or, could that have been from the brakes?
I obviously checked the oil level and all is good there. The car drives fine and there is no more smell. From now on, I plan on driving slowly while in reverse.
Thanks in advance for your input.
Thanks for the input RPVantage. Would you mind elaborating on what you mean by "tall"?
Although I've never noticed this personally, many have reported this same clutch burning smell when reversing and many have speculated it's because of the gear ratio involved ("tall" gearing). I'm sure that's all it is. And your car is past the break in period by now. I wouldn't worry about this unless you continue to notice the smell.
What he means is the gear ratio allows the car to travel too fast in reverse which requires additional feathering of the clutch prior to full engagement which causes it to burn quicker. Another way to think of it is to imagine if you had to start out in second gear all the time. Hence the term "Tall". On the other side, "Short" gears like 4:10's require you to shift much sooner. Reverse in the vantage should be more like first gear but its actually more like second...Did this help or just confuse you more?
Yup, what you smelled was the clutch--however, I'm sure you did no damage at all. I had the same burning smell in reverse happen a couple of times, then had the clutch replaced (under warantee because of mechanical failure) at about 9,000 miles. Clutch-plate showed almost no wear, that's why I'm sure you did no damage. Reverse is tricky in the Vantage especially is you have to back up-hill.
alpha motoring
10-02-2015 12:04 PM
