Which wheel nuance would you choose?
#32
My only point is that many people who have tried getting deeply concave wheels for the V8V have been a bit disappointed at the results. Because the hubs on the car sit rather outboard on the axles, attempting to increase concavity would increase the offset to the point where the wheel protrudes beyond the fender line. This is particularly true on the front. As a result, the front wheels have almost not concavity and don't wind up looking nearly as awesome as your rendering.
#33
I just got word from the engineering department, we can get close to that, around 0.5 inches of that setup and the look on the rendering on an aggressive AMV8 setup! Most of our setups does have front with slight concave profile, where we go aggressive with it in the rear. If you and any others are interested, we can get you a call scheduled where the geeks explain on what, where and how exactly is done!
#34
I never implied that you didn't fully disclose it was a rendering. I'm sorry if that was misconstrued.
If you're someone who like some degree of spacing and also want concavity then you will likely be able to satisfy both of those on a Vantage. But if you want deeply concave _and_ have the rubber more or less flush with the arch, you've going to be disappointed.
#35
When talking about wheels, you need to take into account that some wheels (like ours) are custom created with our customers. This means no spacers are used, no rubbing is seen with our setups and we make sure the fitment is perfect regarding customer's wishes. With that being said, I'm sure that we can deliver a setup that will offer goodies from both worlds (concavity and flush fitment) with an AMV8 setup! It all depends what he/she would want.
#36
Agree. You can see this effect on the wheels that Stewman has (posted earlier in the thread). There were also spacers used I believe but I think he's going to post more detail on that wheel at some point soon. But you can certainly see the effect of the relative lateral position of the hub in the wheel well on the rears in that pic.
#37
As karlfranz explained. You need aggressive fitment to keep the concavity of the wheel as much as you can possibly do. Any movement of the wheel's center to the wheel arches results in less space to use for a concave design. That's why most concave designs have almost no lip in front of the spokes which are in hand placed all the way to the end of the wheel. If you are going for a lip, then the opposite is what you want, but in those cases most people want no concavity at all with it.
#38
I'm not sure I follow your logic. If you want the maximum amout of concavity, you don't want to use any spacers. By keeping the wheel mounting surface of the hub as far inboard as possible (i.e. no spacers) and making a wheel design with an offset that brings the rim edge and spokes as close as possible to the wheel arch you will maximize the concavity.
I was not sure why Stew's wheel set up also had spacers but perhaps he'll explain when he posts a thread on his car.
#41
Here are a couple more pics of my car from a shoot the previous owner did, in case you decide to go with the VS1's ...
#42
Thanks for the kind words, we really appreciate it! You can always get the VS1 without the fasteners, if you want a cleaner look for example. Or go with the monoblock, then select MB1 and get the spokes all the way to the wheel end and get more filled wheel arches that way, what ever you like! We always make sure each and every request from our customers is filled! That is the only way to go.
#43
I will take more pictures of my set-up this long weekend......i too wanted something stylish and something that didnot detract from the iconic beauty of the aston all the while maintaining its prestige....
The rear fitment was near perfect...I just could not get the cap to snap in completely..so I went with the smallest speacer to address this..the mfg. was willing to correct this for me and promises to address this in the future...but with long distance shipping it was not worth it to me...to counter this irregularity i put a slightly larger spacer on the fronts.
The rears are deeply concave and fronts slightly...20x10.5 and 20 x 8.5...I should have went with ( 9) on the fronts...no big issue,,,every angle has different and appealing features..that is all i wanted..new shoes for a new to me car......the comments and people wanting to take photos continue
