aston martin rapide problem
Old Nov 12, 2013 | 11:50 AM
a.c.'s Avatar
a.c. is infamous around these parts
The car was driven on regular service 07.10.2013 in Udine, Italy and it crossed 16000 km and we haven’t had any problems with it , it worked perfectly until now.
The car was parked in the garage, after a few days I tried to start it and it couldn’t start engine.
The day after I tried again and engine is started but the board computer displayed errors :
-ENGINE WARNING LIGHTE
-CHEK FUEL SYSTEM
-ENGINE SYSTEM SERVICE URGENTE
-EMISSION SYSTEM SERVICE RQUIRED
AND THE ENGINE SWITCHED INTO SAFE MODE AND NOW IT WORK AT HALF SPEED UP TO 4000 REVS!
Can anybody tell me what could be the problem because the nearest sevice center is 1200 km away!
Old Nov 12, 2013 | 12:10 PM
buzzm's Avatar
buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !
if you are that far from the dealer you should def buy yourself a code reader, you would be able to pull the codes and see whats wrong
good luck
Old Nov 12, 2013 | 12:27 PM
Stuart@VelocityAP's Avatar
Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !
Sounds like it could well be a battery or storage issue, depending upon how you've been using it. As mentioned, a code reader will tell you what issues may be present and should reset the codes for you and take it out of safe mode as well.
Sometimes these cars 'over-react' a little bit. Might be nothing to worry about.
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
Office: (1)250-485-5126
www.velocityap.com
Old Nov 12, 2013 | 01:45 PM
a.c.'s Avatar
Thanks a lot! Can you recommend me some code reader?
goto35
Mar 8, 2020 07:41 PM
Ellipsis
Mar 28, 2016 03:28 PM
Korntera
Sep 15, 2015 08:20 PM
spinecho
Sep 6, 2015 08:35 PM
