- Mobil1 75W-90 "LS" Gear Oil Review -
Old May 19, 2014 | 03:42 PM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
Mercedes used to say lifetime fill and then all the transmissions started to blow (back in the 90s), now they have a 4yr service cycle. No ATF is lifetime fill truly. But if they are insistent then just do the differential with 2 quarts of mobil1 synthetic.
Old May 27, 2014 | 04:32 PM
Wildcat1212's Avatar
Wildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of light
I have been reading about "lifetime" in lot of life time filled fluids.
I have BMW 750 Li, and lot of forum says change ATF at 60k miles as life time means 100000 miles for transmission and then it can go .
Since dealer is not interested in changing it, does any one have guide how to do it by your self?
Old May 27, 2014 | 05:56 PM
telum01's Avatar
For an Aston or a BMW? BMW write-ups should be out there on BMW forums. There's a write-up for Aston floating around our forum somewhere.
Old May 27, 2014 | 06:19 PM
Sorry for not being clear. I meant was BMW says for life but seems to me that lot of people are changing ATF in BMW at 60k miles.
So I think we should probably change ATF too. I have 2009 DB9 automatic. I could not find DYI for DB9 ATF change if you see it please point me. Thanks
Old May 27, 2014 | 11:49 PM
Technically they are right... It is a "Lifetime" fill, but what they don't tell you is by not changing it that lifetime will be much shorter lol. Most manufacturers stopped using lifetime fill a while ago bc they were running into legal issues stating that so now they usually do 4-6yr service cycles.
jaehoppa
Oct 22, 2015 09:17 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
GSP
Sep 9, 2015 05:31 AM
ECS Tuning - VW
Sep 2, 2015 01:47 PM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
