DB9 Euro Rear License Plate Holder Conversion
I saw this REAR NUMBER PLATE LIGHT TRUNK LAMP ASSEMBLY on aston martin bits http://www.astonmartinbits.com/models/4-DB9/parts/1906 I was wondering if anyone has fitted this part to replace the US fitted rear license plate holder. Those big black license plate lamp holders looks hideous and really make our US DB9's look quite dated.
I have a friend with a very early DB9 and his car has the euro-style rear license hardware. It looks way better. I've been tempted by that part on ambits too.
Any idea how your friend covered up the pre drilled holes visible on our US trunk lids after the plate and light housing is removed.
His car was one of the first 50 built -- it just came that way. They must have changed it later.
see this post on other forum
bringing this back from the dead. anyone here tried this? Would love the idea of the attached image on the db9 - assume it's a pain in the arse with the drill holes etc...
https://cimg3.ibsrv.net/gimg/www.6sp...3d8c8de4ee.jpg |
Simplest solution is to just get the DBS or 2013+ DB9 truck lid and covert over to that. :)
I have one for a Volante if anyone is interested. Got that by mistake rather than a coupe version which I will need after this one is sold |
Originally Posted by jyu12
(Post 4086459)
The AM Bits part goes to the DBS/2013+ trunk lid. NOT a regular DB9 trunk lid. While it may be possible to retrofit, there likely will be a lot of cutting and fitting to afix. Plus I think there is about 6 holes that a body shop will need to fill and paint, if I remember the DIY conversion thread correctly. |
what’s the colour on that gene? |
Originally Posted by astonChap
(Post 4759969)
My 2010 DB9 has the same ugly bumpers and I wanted to do the same following this example: https://www.6speedonline.com/forums/...ate-mount.html
But when I took everything apart I found my boot lid is completely sealed -- there is no underlying plate as I've seen on other conversion examples. Here's a photo of how mine looks: https://cimg4.ibsrv.net/gimg/www.6sp...2c581c3ce7.jpg Does anyone else have a boot lid like this? |
Originally Posted by DB9
(Post 4759976)
But when I took everything apart I found my boot lid is completely sealed -- there is no underlying plate as I've seen on other conversion examples. Here's a photo of how mine looks: https://cimg4.ibsrv.net/gimg/www.6sp...2c581c3ce7.jpg Does anyone else have a boot lid like this? You need- and this is not all of the items due to listing off the top of my head: Bootlid carpet, rear plate and button light fixture, new badges, AM wings, wiring harness for bootlid, plastic clips for bootlid carpet, suggested new hinge for latch, suggested new bumper bolts, suggested leather pull down strap, Third brake light lens and fixture, etc.... Your hinges, shocks will transgfer over and you don't need to even remove them from your car. Early DB9's have the radio antenna under the carpet on the bootlid. So that has to be retrofitted for the new bootlid which there are no mounting holes (not a huge issue, just place under carpet and that will hold down. Biggest issue fo rme was the wiring harness for all the items was NOT the same plug as the early DB9's. So you will have to figure out what goes to what on the in car plug, then TAP into the wires BELOW the plug and run them to the wires for the bootlid. That way you are not really changing anything on the car itself. BUT...... Third brake light for early DB9's is in the rear window, not the bootlid. So you must find those wires, unplug from the light itself, then tap into them and run to the bootlid. None of this is difficult by any means, but I learned alot of what works and what doesn't by at least getting to the stage where I found out my Volante bootlid doesnt work on a Coupe. :( Felt like an idiot, but bought from a forum member and they didnt realize it either. Not a cheap mistake, but hopefully someone will want it. |
Originally Posted by SheriffDep
(Post 4759975)
"gene" Not sure what you mean if your referring to the bootlid I have, its finished perfectly in Jet Black, but most likely will need scuffing and re-spray. It was grey when I got it.
