AM V8 window isssue---- i think
Old Jun 18, 2014 | 12:26 PM
XWCGT's Avatar
XWCGT has a spectacular aura aboutXWCGT has a spectacular aura aboutXWCGT has a spectacular aura about
This has been bugging me since I got the car. when I open the door the window drops down 1/4" to not hit the door trim. I get that. BUT shouldn't it do it faster so it doesn't sound like it its hitting before the door gets past the trim? its like its not fast enough, even if I open the door real slow, it will hang on the trim slightly.
is this adjustable in software? something I have to live with?
Old Jun 18, 2014 | 01:06 PM
karlfranz's Avatar
Doesn't sound normal. Mine always clears the trim just fine. However, when I first got the car the back upper corner of the glass used to hit the rear quarter glass a bit. It was adjusted by my dealer under warranty.
Old Jun 18, 2014 | 07:26 PM
XWCGT's Avatar
it seems like its not coming down fast enough, and wonder if that is a software adjustment. its almost like the function that its trying to provide isn't cutting it.
Old Jun 19, 2014 | 07:48 AM
AMFixer's Avatar
AMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to all
There is no software adjustment that can be done to increase the speed. Sometimes a adjust to the window in the regulator can help, or even a adjustment to the door.
Old Jun 19, 2014 | 01:29 PM
XWCGT's Avatar
Thanks! I wonder if when they replaced the door computers they messed with the window regulators. if so, that would explain the mis adjustment then. does anyone know if replacing the computers, involves touching the regulators ?
Old Jun 19, 2014 | 01:30 PM
AMFixer's Avatar
No you don't need to touch the regulator to change the door module. Why did they change the door module's?
Old Jun 19, 2014 | 01:52 PM
karlfranz's Avatar
^^^^ Probably because of Service Bulletin #0304V2.
Old Jun 20, 2014 | 01:44 AM
XWCGT's Avatar
The doors didn't lock with the remote, only the key. not even the internal electronic lock button. So, they changed one door module, but of course, they have to match, so I needed both sides. great design! anyway, as a plus, with the door computer change, the mirrors close when you lock the car. almost worth the price of admission!
Old Jun 20, 2014 | 06:42 PM
AMFixer's Avatar
There was a update to the door module's. If you have the older style you need both and a update to the car configuration file to make them work. They should have calibrated them when they installed them. Other than that sounds like a slight window glass adjustment maybe needed.
Old Nov 19, 2014 | 11:11 PM
XWCGT's Avatar
yeah, it seems like its an issue. you would think that the shop (AM shop) would have done this. I have to open the latch, wait for the window to drop the 1/4" and then open the door otherwise it catches. doesn't seem like this is normal at all. I guess I should go to the shop and have them adjust the window again.
Highlander
Dec 21, 2015 08:42 PM
Glasgo
Nov 30, 2015 02:37 PM
Perkman87
Nov 19, 2015 05:31 PM
Vantagelvr
Oct 4, 2015 07:27 AM
Mz3bo
Oct 1, 2015 06:32 PM
