iPhone 6 -- there's got to be a better way...
So, like thousands of other lemmings, I got my iPhone 6 today. I actually skipped the iPhone 5 (I upgraded from an iPhone 4S) so this is the first time I had to deal with the new lightning adapter.
I have a 2008 V8V and up until now I've had to make do with the Scosche IFWA adapter. But now with both the Scosche adapter and the Apple 30-pin to lightning adapter it is getting out of hand. Is there a better way? http://www2.crutchfield.com.edgesuit...iFWA-f_dg.jpeg http://cellphoneshop.com/yswimages/30pin.jpg |
Originally Posted by jyu12
(Post 4199055)
That's fine for playing music but it won't charge my phone. Do you use the air play adapter and a cigarette lighter charger? |
I have iPod connectivity in my '07 V8V. It uses a couple of components to integrate into the existing system but all you see is the iPod charge cable itself, which is made by iSimple. Very good quality and supports both charging and audio. I use it for an iPod, though (don't have an iPhone). Might be worth looking at their products.
Originally Posted by programmatore
(Post 4199061)
Originally Posted by telum01
(Post 4199093)
-d |
(Post 4199093)
Ron |
Aston have just released a kit that will allow bluetooth audio streaming on all cars including early DB9 and Vantage. The car does have to have the factory bluetooth option.
Originally Posted by Coxy-jr
(Post 4199273)
Mine is similar to Ron's but fully aftermarket. It uses an iSimple cable (includes converting between components and digital signal) and a JL Audio link thing. Can't remember the names for everything off the top of my head. I also have a switch that I have to activate (overrides the FM signal, which is completely off while the iPod is active). My switch is under the dash, and my iPod cable comes out of the glove box next to the transmission tunnel.
You can upgrade the ipod connection kit from Aston..does cost $$$, but it's a solution to having the phone charge and with OEM parts..
Also, not sure if you guys know but Aston just came out with a upgrade kit to the Bluetooth equipped cars, you can now stream Bluetooth...just came out this past August Then you can try a Audi AMI cable for Lightning connector (it's an idea, I've never tried this, I'm sure someone on here has a friend with an Audi that has a Lightning cable to try)..here's what it looks like: http://www.advanced-incar.co.uk/audi...ightning-cable |
Introduction of Bluetooth audio streaming (A2DP), allowing music to be played wirelessly through the car audio system
Compatibility with the latest smartphones, including Apple, Android, Windows and Blackberry Larger phonebook access – 2500 contacts, up from 750 previously Fast scroll –the tone rotary controller can be used to quickly scroll though phonebook contacts by first letter or through tracks during audio streaming Two call handling, giving the opportunity to switch to a new incoming call during an existing one Full call list synchronisation, making the most recent missed calls, received calls and recently dialled numbers available on the display screen Phonebook synchronisation, ensuring a complete update of stored contacts each time the phone connects via Bluetooth Updated phonebook symbols to distinguish between home, work and mobile numbers saved against a contact. Microphone gain – sensitivity is now adjustable to allow for different phones and driving scenarios Enhanced privacy – drivers now have the ability to choose whether or not to synchronise or download their mobile contacts on to the system Ringtone – volume level is now adjustable Access to voice recognition software, such as Siri Additional language support Bluetooth Update for DB9 V8 Vantage 2008 MY on $900 Pre 2007MY $1800. Is what I was quoted from the dealer |
Originally Posted by J doubleU
(Post 4200311)
Compatibility with the latest smartphones, including Apple, Android, Windows and Blackberry Larger phonebook access 2500 contacts, up from 750 previously Fast scroll the tone rotary controller can be used to quickly scroll though phonebook contacts by first letter or through tracks during audio streaming Two call handling, giving the opportunity to switch to a new incoming call during an existing one Full call list synchronisation, making the most recent missed calls, received calls and recently dialled numbers available on the display screen Phonebook synchronisation, ensuring a complete update of stored contacts each time the phone connects via Bluetooth Updated phonebook symbols to distinguish between home, work and mobile numbers saved against a contact. Microphone gain sensitivity is now adjustable to allow for different phones and driving scenarios Enhanced privacy drivers now have the ability to choose whether or not to synchronise or download their mobile contacts on to the system Ringtone volume level is now adjustable Access to voice recognition software, such as Siri Additional language support Bluetooth Update for DB9 V8 Vantage 2008 MY on $900 Pre 2007MY $1800. Is what I was quoted from the dealer |
I think part of it is that pre-08 isn't a simple plug-and-play. It's very labor intensive. My kit was $1300 installed, half parts and half labor.
(Post 4200322)
| All times are GMT -6. The time now is 12:33 AM. |
