Go Back  6SpeedOnline - Porsche Forum and Luxury Car Resource > British > Aston Martin
Reload this Page >
Early DB9 replacement Euro rear license plate mount
Notices
Old 03-15-2019, 08:38 PM
SheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to all
Originally Posted by Alien32 View Post
Another old thread, and another happy 'customer'! Thanks for the idea. My 2005 had a few oddities when I purchased it (from a used car dealer). The front plate holder was the euro spec. The rear had the US bumperettes, but strangely they didn't have any illumination. When I pulled them (and the rear license plate holder off) to rectify that so I could pass Texas inspection, I discovered someone had already put in the Euro style license plate lights and trunk release so it was a no-brainer to do as the OP did. I covered the holes with some spare Xpel until I could get them filled and painted.
I've since had the holes filled and paint done at Katy Coach Works. I couldn't bring myself to just drill holes into the decklid since it's two layers with a gap, so I instead have a thin 'adapter plate' to match the US plate and 4 of the existing holes.
The trunk release alone makes this modification worthwhile.
Gary,
Could you post a picture of nighttime with the light on please. I just did this today, and well the plate is NOT lit up hardly at all. The lights focus more back to the top part only. Thanks
Old 03-15-2019, 10:02 PM
Alien32's Avatar
Alien32 has much to be proud ofAlien32 has much to be proud ofAlien32 has much to be proud ofAlien32 has much to be proud ofAlien32 has much to be proud ofAlien32 has much to be proud ofAlien32 has much to be proud ofAlien32 has much to be proud ofAlien32 has much to be proud of
Hmm... never really paid attention to it at night. I did replace the license plate and trunk lights with white LEDs which helps. The picture does show it a bit brighter than what it actually is in person in the garage tonight with garage door light off.
Old 03-16-2019, 05:04 PM
what did you do to make it so bright, mine even with LEDs doesn't illuminate the whole license plate, just the top part. NOW i am using the light bracket for a DBS trunk. Maybe early european brackets are what is needed. If you can let me know that would help
Old 03-16-2019, 06:27 PM
Alien32's Avatar
I really didn't do anything special other than good LED bulbs. Like I said, the camera does make it appear a bit brighter than it does in person. Mine was put on by a previous owner, not sure what the p/n or which one it is. Maybe you could space out the bottom bolts further to angle the plate more?
*edit* Mine are this style bulbs. Not sure what the difference is between these and their Zevo line *edit*
https://www.amazon.com/SYLVANIA-White-Bulb-Contains-Bulbs/dp/B079ZC1GM6/ref=asc_df_B079ZC1GM6/?tag=hyprod-20&linkCode=df0&hvadid=312089957955&hvpos=1o2&hvnetw=g&hvrand=16057173315735273603&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9027731&hvtargid=pla-584223609322&psc=1 https://www.amazon.com/SYLVANIA-White-Bulb-Contains-Bulbs/dp/B079ZC1GM6/ref=asc_df_B079ZC1GM6/?tag=hyprod-20&linkCode=df0&hvadid=312089957955&hvpos=1o2&hvnetw=g&hvrand=16057173315735273603&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9027731&hvtargid=pla-584223609322&psc=1
Burn Meter
Merchandise For Sale / Wanted
08-31-2015 10:19 PM
gulf gt
08-27-2015 10:27 AM
TrackOne
08-20-2015 12:56 PM
pwdrhound
08-20-2015 05:54 AM
Jeff1smith
08-19-2015 09:41 PM
Quick Reply: Early DB9 replacement Euro rear license plate mount
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
