V8 Vantage Twin Plate Organic Clutch & Flywheel OEM Replacement Upgrade
Old Aug 29, 2015 | 08:02 AM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
Originally Posted by jmargolese
Thanks for the details. I'm getting close on mine as well and will head this route. What did the dealer charge for install?
PM Sent
Old Aug 31, 2015 | 07:01 AM
flinder's Avatar
flinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to behold
It has even helped me "rev match"
DonL, Glad to hear of your successful clutch/flywheel upgrade. Sounds as if your experiences at the dealership, and improved vehicle function as a result, have been the same as mine.
Over the 8 years I have had my V8V I have made about 35 modifications. Of all these, this one, the great twin plate clutch & billet steel flywheel project, is best. The improvements are recognized during every seat of the pants dyno excursion.
If I was still working, I would be taking the long way home.
Old Sep 1, 2015 | 11:03 PM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
It fixes all of the shifting notchiness too, it's amazing how much of the transmissions flaw stem from the poor OEM clutch design.
Definitely do the upgrade if you have to replace a failed clutch anyways.
Old Sep 2, 2015 | 12:51 AM
Stuart@VelocityAP's Avatar
Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !
Have you done this upgrade?
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
Office: (1)250-485-5126
www.velocityap.com
Old Sep 2, 2015 | 06:57 AM
My friend did the RSC kit which is similar in nature. It is a massive improvement in shifting quality
Old Sep 2, 2015 | 02:38 PM
evermore's Avatar
evermore is infamous around these parts
please pm too?
Originally Posted by DonL
PM Sent
Hi, I would be interested to hear how much this would run me as well (I'm over in Santa Clara and still shopping for a Vantage).
thanks!
Michael
Old Sep 2, 2015 | 02:47 PM
We are down to our last unit in stock, more inventory is on the way, but if you're in the market you better move quick
PM Me for 6Speed Pricing.
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
www.velocityap.com
Old Oct 14, 2015 | 01:32 PM
Hello All. We are just re-stocking these parts, and filling a couple on back order at the same time. If anyone is interested let me know
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
www.velocityap.com
Old Feb 19, 2016 | 12:10 PM
Back in stock for immediate shipment!
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
www.velocityap.com
Old Feb 19, 2016 | 04:36 PM
SUFitness's Avatar
SUFitness is infamous around these parts
Hi there, can you give me a quote for the twin plate clutch and flywheel?
I have a 2015 vantage GT and I live in La Mirada, CA 90638.
Old Apr 28, 2016 | 01:17 PM
Back in stock again... can't keep these on the shelf.
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
www.velocityap.com
Old Jul 28, 2016 | 11:40 AM
105Ian's Avatar
105Ian is infamous around these parts
V8 vantage flywheel and clutch
Hello Stuart
Now I maybe barking up the wrong tree here , but as the Aston Vantage V8 is based on the Jaguar AJ V8 would you kit work on a 2002 Jaguar s type r using the 4.2 supercharged version , as in the process of trying to find a flywheel and clutch to mate it up to the Jaguar diesel gearbox wich uses same bell housing pattern and being a diesel gearbox should handle the torque , the engine is being fitted into a 1970 Escort , so probably not your normal style vehicle .
Thanks for your advice , cheers Ian
Old Jul 28, 2016 | 06:11 PM
Originally Posted by 105Ian
Hello Stuart
Hi Ian,
The clutch is just a clutch, and the hydraulic release bearing/slave is just a hydraulic bearing so as long as you can drill & tap the bell housing to receive the bearing, and then shim it to be the correct distance from the clutch cover, that can in theory work. Basically, that stuff is all mechanical and really within reason, most clutches with matching bearings can work in there. The critical thing will be - is the bolt pattern on the crank the same as the V8V, that I can't tell you. Could send you a used OEM flywheel perhaps, to try and see?
At that point you have to do some engineering & measurement to ensure that the flywheel will fit in the bellhousing, that the gear pattern is correct to engage the starter motor, and that the deck height is workable in terms of the distance from the crank face to the bearing face.
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
www.velocityap.com
Old Jul 29, 2016 | 03:28 AM
105Ian's Avatar
Hi Ian,
Hello Stuart , thanks for your reply like you say clutch could easily enough be sorted it's the flywheel having problem with , after some machining have managed to get a Jaguar 2.7 diesel flywheel onto the crank as bolt pattern the same but ring gear will not work and beeing a dual mass flywheel, it's far to heavy , if you could send me a flywheel that would be extremely helpful in moving forward with the issue , would think this would cost a lot to send to England though , do you have an idea of shipping costs ?
Thanks again , cheers Ian
Old Jul 29, 2016 | 10:15 AM
Sent me an email Ian, stuart@velocityap.com I have partners in the UK.
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
www.velocityap.com
