Problem Accessing my DB9's Quarter Window Actuator / Regulator
Old May 2, 2016 | 03:44 PM
Subzero288's Avatar
Subzero288 is infamous around these parts
I was wondering whether anyone might have advice or tips on tackling a problem with my '07 DB9 Volante:
Apparently, the pin on the passenger side (under the tonneau cover) that slides in and out (locking the tonneau in place) isn't moving so the convertible top won't raise/lower. However, my mechanic is having a hard time accessing the top mechanism because the little passenger-side quarter-window is in the down position (and in the way). The rear-quarter glass needs to be raised up, independently of the top mechanism, to work on the car.
Is this something anyone's ever come across and/or does anyone know the easiest way to access the window motor and operate that small window? It's hard to reach because of how its positioned and the amount of space in there.
I'd appreciate any suggestion(s) anyone might have.
Thanks,
Thomas
Old May 2, 2016 | 04:28 PM
randyb's Avatar
randyb has a spectacular aura aboutrandyb has a spectacular aura aboutrandyb has a spectacular aura about
I have the same issue, from the service manual it looks like you gain access the the locking mechanism through the trunk with the roof raised.
But that is my guess, it does not actually say clearly how to get access.
Old May 3, 2016 | 08:10 AM
Subzero288's Avatar
Thank you.
Please let me know if you have any success accessing the motor in that way.
Old May 3, 2016 | 03:12 PM
Subzero288's Avatar
Randy,
I was able to obtain a copy of an official Aston Martin technical bulletin that provides step-by-step instructions for removing the quarter-window glass and repairing/replacing the convertible roof actuator. The bulletin suggests that water seepage may be the culprit.
Please message me directly if you'd like me to email you a copy of the document.
Old May 4, 2016 | 10:39 AM
randyb's Avatar
Great thanks
Old Feb 15, 2019 | 02:21 PM
EKing's Avatar
EKing is infamous around these parts
Would it be possible for you to forward a copy of the bulletin pertaining to this thread, please?
Thank you.
Old Feb 15, 2019 | 02:37 PM
Subzero288's Avatar
Talking Sure thing . . .
Thank you.
It's attached as a PDF. I hope it helps!
Old Feb 15, 2019 | 04:25 PM
randyb's Avatar
there are steps missing, just so you know.
Old Feb 15, 2019 | 05:20 PM
Subzero288's Avatar
The auto body shop I brought it to had no problems following the instructions and making the repair.
Old Feb 27, 2019 | 10:21 AM
randyb's Avatar
The missing steps are obvious, one is removing the screws holding the convertible trim pieces to the panel and I forget the other. But it was obvious too.
Old Nov 17, 2025 | 03:48 AM
khanmurtaza's Avatar
khanmurtaza
Randy,
Hi Mate, Are you able to share the document of how to remove quarter window from down position? I think my actuator is fried.
BarrettG
Jun 1, 2016 09:10 AM
Ducatista
Cayenne 955/957
Apr 28, 2016 01:37 PM
xmaciek82x
Apr 15, 2016 07:02 PM
///M Kevin
Apr 12, 2016 04:32 PM
