My DIY Radar detector hard wire
Old Jul 2, 2016 | 06:33 PM
adnanm3's Avatar
adnanm3 is infamous around these parts
In my past cars I have just used the AC adapter, but with the Vantage only having one available...I thought I would hard wire my Escort.
When I went digging around in the headliner I found a few different options but thought it would be nice to have a power input that I could turn on and off with he push of a button
Who needs two dim interior lights anyway?
Old Jul 2, 2016 | 08:27 PM
alexhuth's Avatar
alexhuth is infamous around these parts
Originally Posted by adnanm3
In my past cars I have just used the AC adapter, but with the Vantage only having one available...I thought I would hard wire my Escort. When I went digging around in the headliner I found a few different options but thought it would be nice to have a power input that I could turn on and off with he push of a button Who needs two dim interior lights anyway? Video Link: https://youtu.be/1INP9fiY_Xk
Awesome!
Old Jul 3, 2016 | 12:04 PM
GDay2's Avatar
GDay2 is a jewel in the roughGDay2 is a jewel in the roughGDay2 is a jewel in the rough
Great idea!
Old Jul 4, 2016 | 10:56 PM
shootermcgav1n's Avatar
shootermcgav1n has a spectacular aura aboutshootermcgav1n has a spectacular aura about
wow that's pretty awesome, any more in depth details on your install? if not step by step at least how you got power to the unit? i really do hate the phone cord style power input on my passport 9500 but i REALLY want to hardwire it since running the cord to the one and only outlet is just an awful option. not sure really where to start but what you've done could be exactly what i've been looking for.
Old Jul 5, 2016 | 08:26 PM
adnanm3's Avatar
It's very simple. There's one screw that holds up the console behind the rearview. Remove and you will see the wires that feed to the illuminator lights. I spliced and removed the wire from the pass side light and spliced the wire from the radar detector cable. Connected a 12v stand alone fuse then connected + to + and ground to ground. I forgot which wires were which...I just did some trial and error.
Now I do not have a pass side illuminator light...I just left the casing intact so it looks stock.
Huge upgrade for me now that I don't have a huge chord dangling down to my center console.
Old Jul 5, 2016 | 08:54 PM
That looks like an Escort Max unit, does it also use the phone cord power connector? if so do you remember what was the wires you bought to splice? sorry for the noob question but where did you get the stand alone 12v fuse?
Thanks in advance.
Old Jul 8, 2016 | 09:55 AM
Mathman85's Avatar
Mathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to all
Thanks in advance.
Escort sells hardwire kits that include an in-line fuse. Available on Amazon, too.
Old Jul 8, 2016 | 12:23 PM
karlfranz's Avatar
Cool implementation but I'm not sure I understand why you would want to ever shut off your detector.
Old Jul 8, 2016 | 12:31 PM
telum01's Avatar
They're illegal in some states. If you ever pass through VA, better have it completely turned off... also don't speed. VA sucks for drivers lol
Old Jul 9, 2016 | 07:10 AM
embdenb's Avatar
Not sure shutting the detector off helps. If the cops see it in the car I am pretty sure they will confiscate it.
Old Jul 10, 2016 | 11:31 AM
don't think they're allowed to confiscate, but you'll def get a ticket?
Old Jul 10, 2016 | 02:51 PM
Teekster's Avatar
Teekster is infamous around these partsTeekster is infamous around these parts
So unless you are routinely driving through VA, I'm not sure I see the benefit of having it switchable vs turning on with the car. I ran a power wire from the fuse box (with an add-a-fuse kit) up the right a-pillar and to the detector. Grabbed a ground behind the map lights. Totally invisible and easily reversible to stock.
pikajew
Apr 19, 2016 12:56 PM
Gene G
Apr 15, 2016 10:47 PM
SimonB
Apr 11, 2016 02:45 PM
455 Stage-1
Apr 9, 2016 04:26 PM
spyder997s
Apr 7, 2016 12:45 PM
