07 DB9 Seat Calibration
While replacing the 1/4 window regulator, I let the battary get low and the drivers seat lost its calibration.
I have tried and tried the relearning procedure, seat all the forward, front of seat all the way and then the rear lower seat all the way up and then the back rest all the way forward and seat still will not go down and backwards. Is there anyway to know if the seat module is awake and should the seat switches make a sound when activated? Took a little over 3 hrs to replace the regulator and am on day 3 of the stupid seat recalibration. :mad: |
Press the seat bottom front portion up until it's all the way forward and hold for three seconds, then repeat with the seat bottom rear upward, then move the seat bottom all the way forward... As you are holding the bottom and it has moved all the way forward, have someone push the battery disconnect button in the boot. When you reconnect the battery(yellow button under rear passenger seat), the seat should start operating normally.
Originally Posted by Timodc
(Post 4544902)
Pull up the rear passenger seat bottom cushion. It will be under there.
(Post 4545208)
Still cant get the driver side seat to recalibrate, anybody know if these are the right steps?
1) disconnect battery (2 minutes, but I have left it disconnected overnight) 2) Key turned to the ON position 3) Bottom Seat button pushed to move the seat all the way forward and hold for 4 seconds 4) Bottom Seat front incline all the way up and hold for 4 seconds 5) Bottom seat rear incline all the way up and hold for 4 seconds 6) backrest all the way forward and hold for 4 seconds. |
Doesn't sound right to me (the part about the backrest). Regardless, isn't it covered in the owner's manual?
No, not covered in the owners manual, did find someting in the service manual. The only difference is that the backrest is not part of the reset and you have to hold the botttom seat in the UP adjustment setting and have someone push the battery reset button at the sametime. Going to try this tonight, as it was raining lastnight.
After days of messing with these seats, it suddenly let me calibrate the drivers seat. Left car sitting for 3 days, I walked up unlocked the door and started to try and reprogram and it took. I did not put the key in the ignition or anything, weird.
But the passenger seat stopped working, which is strange, because it was working fine the last time I tried to move the seat. |
