09 Vantage V8, lowered - tire fitment question with 20" wheels...
Could be an optical illusion, but that looks like a lot of negative camber - is that for fitment to avoid rubbing? What camber are you running?
lot of it probably is optical, since it's so wide in the back. it's lowered on h&r's, not sure what the exact specs are as i didn't do it myself. i will probably get an alignment in the not so distant future so will report back.
That's not enough rubber on these wheels, you should have run
255/35s and 305/30s to be closer to specs...
You wheels look very nice but need either black satin or glossy for my car
