Originally Posted by superuser
(Post 4651794)
Awesome, just ordered a set!
Originally Posted by Kanga
(Post 4648838)
The great thing about the filter adapters is that you can use a range of filters with them. Factory AML works, Redpants new dry filters or K&N. The redesigned bracket is very secure once fitted and extremely strong, the internal structure is a 3d honeycomb ABS for added support. The final set is just coming off the 3d printer and should be with Rich next week.
Rich and I were talking about it and thinking it may be best to keep it even without any air boxes as it still should push air to the open filter. |
(Post 4651812)
When you install them the flange on the side points down and the locating tab on it is closest to the center of the car. Make sure you remove the rubber grommet and sleeve from the bracket that is bolted on to the car chassis. The tab then fits into this bracket and you use one of the original bolts with a washer and nut to locate it. I'm sure Rich will do a video to show how to fit them.
2 Attachment(s)
Installed Rich's/Redpants air box deletes today in roughly 45 minutes. It's a straight forward job with the only trick being the removal of the rubber grommets mentioned above by Kanga (thanks). I also had to pull the vacuum tube from the manifold the connects to the n400 style air boxes.
I can confirm that the fit is great. Neither the air boxes nor the new holder will move around at all. |
Curious as to how much more hp you get with this mod. Anyone know?
Water
2017 WEC Fuji skip ahead to 37 sec - the Astons are back there somewhere
Air intake duct removal
I am in the process of making my own little air box removal mod and wondered if you can remove the intake ducts without taking off more bodywork trim ? I already have the wheel arch liners, under tray, bumper liner and air boxes out. they seem to be very difficult to pull through the gap ? Any help would be appreciated.
Originally Posted by Rwp137
(Post 4653873)
This is a feel good mod. Without any additional changes, I do not believe there is any horsepower gains. That said, removing the air boxes and remapping the ECU should provide an increase in HP. This was the basis for the modification that increased the HP on the 4.3 from 380 to 400. I would also change the cats to the less restrictive units. |
Originally Posted by embdenb
(Post 4695295)
IMHO, None.
My understanding was that be removing the air boxes and fitting a more free flowing air filter, there is a gain in HP. If this wasn’t the case, how could K&N and other air filter manufactures claim a gain in HP. Again, if you’ve got more air entering the plenum chamber (with MAF sensors in place) you should get more fuel, more fuel and air mean more HP ? It’s probably only about 5HP, but just a home project. I’ve already got 200 cat cells and tubi exhaust, so I’m expecting around 400 bhp. |
I have done before/after dynos on most mods over the years and found the 200 cell cats to be the biggest bang for the buck (and improvement in sound). I have done every mod I am aware of to help improve the little 4.3L and am putting down close to 400RWHP
That said I have not done an after Dyno with the air box delete. I did speak with TRG and David Appleby prior to removing and they both shared roughly 10rwhp gain with removal and drillling into the fender liners directly under the filters. |
Originally Posted by DetomasoGTS74
(Post 4695311)
I can chime in as to the system adapting. When I first took mine out I'd get the occasional code. Hasn't happened now in over 6 months of driving including a track day. So I guess it's recalibrated.
Originally Posted by deckman
(Post 4695379)
You were able to get that much more out of the 4.3? What would that be, about 475HP at the crank? That's remarkable.
