Help srs airbag service urgent message
Old Oct 8, 2017 | 11:15 AM
tko211's Avatar
tko211 is a jewel in the roughtko211 is a jewel in the roughtko211 is a jewel in the rough
Red face Help srs airbag service urgent message
06 v8 vantage. I have a srs airbag service urgent light / message on my car. I also have a battery that recently started to exhibit signs of dying a slow death. (Windows trouble adjusting) (slow to turn over if not driven for a couple days)... my question is: is it possible that this srs airbag service notification is related to my battery issue? Does anyone here have experience with this? I tried adjusting both seats to clear the srs code but nothing helped. Thoughts?
Old Oct 8, 2017 | 11:26 AM
Falcon75's Avatar
Falcon75 is infamous around these parts
I had exactly the same problem last July on my 2006 V8 Vantage. After checking all fuses and the seats for something lodged under them without success, I took it to my dealership. It turned out to be a fault in the clock spring module located behind the steering wheel. They replaced the assembly and erased all codes. Everything is fine now. Total was $450.00 for parts and labor.
Old Oct 8, 2017 | 12:40 PM
07sportspack's Avatar
07sportspack has a spectacular aura about07sportspack has a spectacular aura about
Start with a new battery.
Old Oct 8, 2017 | 03:02 PM
Aldv's Avatar
Aldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud of
I agree...battery first...have it tested..next buy a battery tender...
good luck
