Aston Martin Vantage V8 2006 Airbag alert just came on . HELP!
Hi AMV8 folks,
Ive been away for awhile, but have been enjoying the AmV8 vantage for the past 4 years! love it!
However, just tonight, the airbag warning came on..... "needs urgent attention..."
What the heck???
i have a scanner so i guess i could try and clear codes but what do you think happened for it to go on? never any contact. ive heard seat position can trigger it, or that connector under the seat.
any advice??
thanks!
What the heck???
any advice??
thanks!
You'll need a scanner that works on the body module, the connector on the right (engine module is on left). Not all scanners will be compatible. I just got a Foxwell NT510 that reset mine without any problems ( I had the car apart with the front sensors deactivated and turned on the ignition which popped the same code).
charged up the battery which was a little low, and now got in the car and started it up, repeat, and nothing changed. it still goes through the self check at the beginning and says, "urgent check airbag, etc".
one is the body scanner that has the info for things like airbag warning?
anyway, my cheapo scanner cant read the code or even connect via the CAN protocol. reads the engine codes on the other plug , but not the "body" connector.
are there low cost scanners to tap into the body output plug?
do you think there is a problem, or just a fault that came out of my battery voltage being low and now it just needs to be cleared?
I guess ill need to get that to remove the warning.
does everyone think that the warning is just a product of the battery being low, and making an errror code on a weak start, where the voltage drops really low? i have had a lot of error / alerts come up on the dash siince the battery has been weak. security system alert, emmissions alert but they go away after a few starts.
I couldn't get my Autel scanner to extinguish the Passenger Airbag warning (2007 AMV8) for more than a few seconds. I removed the airbag module (it's a Volvo part) from the center armrest position, and prepared to send it to a place that could reset the code. They said that since the car had not been in a crash, there was nothing they could erase. So I put it back in the car, cleared the code with the Autel (set to Volvo XC90). It's been cleared for a month now. :-)
Thanks for all the suggestions. it sounds like i need to buy the Autel scanner to reset the airbag warning, but what about the standard hard /reset method of clearing codes? does that work at all?? (with no scanner, just using the process of holding down the two buttons on the control panel)
I have the same issue, passenger airbag fault, constantly on while seat is empty or with a passenger. Looked underneath, everything seems connected correctly. I havent been able to get a proper scan tool yet, but i'll try and order one. I'm hoping its just another electric gremlin of the Aston and not another expensive component needed.
Global Autosports
03-21-2012 10:19 AM
Global Autosports
03-19-2012 09:11 AM
