Brake caliper help
Old 10-14-2018, 04:59 PM
DetomasoGTS74's Avatar
Brake caliper help
So I have had the often discussed E Brake squeal since installing my Nitron coilovers. Noise is on the driver side and I am certain it is E break related as it goes away when I lightly lift up on the E break.
Today I decided to finally mess with it as I have been embarrassed more than once driving around with it squeaking. I noticed one of my bolts on either side was loose enough that I could tighten by hand, so I lightly tightened both sides with a torque wrench but then the car was literally stuck in place so I backed the bolts to just hand tightened.
I took the car for a drive around the neighborhood and the noise is gone but I swear it feels like the E break is ever so lightly applied (shows off on dash). Obviously I do not want to drive
around with the e brake lightly on but I can’t imagine having 4 bolts (2 in pic below) any lighter than hand tightened.
Does anyone have the procedure to putting the brake caliper back together that may provide direction as to how tight they should be?
Old 10-15-2018, 04:38 AM
handyman2009's Avatar
From what I remember you have to:
1. remove the caliper
2. back or remove the set screw from underneath
3. push the piston back in by rotating it
4. re-align the set screw with the slot
5. put the pads back on and re-install the caliper.
6 pulling on the hand brake will re-adjust the hand brake
That all I did when I changed my pads last year
Old 10-15-2018, 08:04 AM
boxercupdave's Avatar
boxercupdave has a spectacular aura aboutboxercupdave has a spectacular aura about
Handyman2009 is correct and I suspect someone didn't tighten the bolt because they did not know to retract the mechanical piston. Retract the piston before tightening the bolts.
Old 10-15-2018, 10:10 AM
Thanks guys, I was the who installed them and believe I retracted the piston (not 100% certain as it was over a year ago). The e brake would not have worked though had I not retracted prior to tightening, correct? It has been working fine, just the light squeal at times.
Perhaps this may help, in the below picture, do you have the same gap between both sides of the caliper? Thanks!
Old 10-15-2018, 10:13 AM
I will check mine tonight but I don't believe that I have any gap between the front and the back part of the caliper. I will get back to you later tonight when I am home
Old 10-15-2018, 10:20 AM
Appreciate it, that should help to determine if there is a problem then with mine. Probably hard to tell in pic but where aarow is pointing is largest gap (roughly 3-4mm). Other side is about 2mm and neither of the e brake caliper sides are touching. Thanks!
Old 10-15-2018, 10:22 AM
yvr's Avatar
yvr
yvr is offline
yvr has much to be proud ofyvr has much to be proud ofyvr has much to be proud ofyvr has much to be proud ofyvr has much to be proud ofyvr has much to be proud ofyvr has much to be proud ofyvr has much to be proud ofyvr has much to be proud ofyvr has much to be proud of
That gap isn't right -- both sides should be tight together.
BTW -- Porterfield e-brake pads stopped the squeaking for me.
Old 10-15-2018, 10:48 AM
DonL's Avatar
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
The two halves of the e-brake caliper on my Vantage do not have a gap.
More information/pictures at the following link:
https://www.6speedonline.com/forums/...akes-help.html
Old 10-15-2018, 02:52 PM
Pretty hard to take pictures with the wheels on the car but you can see that there is no gap... you probably didn't push back the piston far enough. Good luck with the fix
Old 10-15-2018, 08:24 PM
Thanks for all the replies, pictures and link. I just can't believe I've been driving around like this for over a year engaging the parking brake often, and never having an issue!
I have a staple in my brand new PS4S so I have to take my wheel off anyways and will give this a go in the next two weeks. Seems like a major pain in the butt to get right!
Old 10-16-2018, 01:26 PM
Denny 6.53's Avatar
Denny 6.53 is an unknown quantity at this point
Not to steal the thread, but is a tool required to wind in the pistons on the e-brake caliper? If so, does anyone have a brand name?
Old 10-16-2018, 01:29 PM
not stealing at all, I too would love a brand/link!
Old 10-16-2018, 02:13 PM
I believe that I only use long nose pliers and it is very easy to spin
Old 10-16-2018, 04:54 PM
Denny 6.53's Avatar
Thanks Handyman. I wondered. When I did rear brake pads, I purchased a tool to retract the brake pistons. They went back in so easily that I returned the unopened tool. Thanks to Redpants Rich for the tech tip.
My car is a 2011 V8V S roadster. I recently put in a new battery and came up with a little trick that may help someone else. Check my post titled "the battery is in". Thanks to everyone on this site
Old 10-17-2018, 03:43 PM
J doubleU's Avatar
Quick Reply: Brake caliper help
