AGM or non AGM battery
Old 01-23-2019, 02:12 PM
lovingit's Avatar
lovingit is on a distinguished road
Dealer is selling an Interstate non AGM battery for v8v for $275. I found an Autocraft AGM battery for $190. Dealer says for our cars, AGM does not really matter. I've always thought AGM batteries last longer. Thoughts?
Old 01-23-2019, 03:55 PM
Gene G's Avatar
Gene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond repute
If it doesn’t matter then why pay the stealer an extra $80 ?
Old 01-23-2019, 04:50 PM
englishmatt's Avatar
englishmatt is an unknown quantity at this point
AGM holds the charge better when not used often. So, if you don't use your car often and do not have a trickle charger...AGM will last longer before needing a charge. I have AGM in all my bikes that do not get ridden but once or twice a qtr.
Also, AGM doesn't need to vent.
I just replaced the battery in my car with a Duracell Extreme AGM.
Old 01-23-2019, 05:11 PM
007JB's Avatar
007JB has a spectacular aura about007JB has a spectacular aura about007JB has a spectacular aura about
what's the part # you use for duracell? how much you paid ?
Old 01-23-2019, 05:38 PM
SheriffDep's Avatar
SheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to all
I got the same one a week ago-----AGM Duracell was $212 including tax
AGM battery is what our cars are made for, has the small vent tube on the left side.
Old 01-23-2019, 07:08 PM
Duracell Ultra Platinum AGM BCI Group 94R Car and Truck Battery
SLI94RAGM
Got it from batteries plus for $199. It’s a perfect fit. AGM batteries do not have a vent tube.
Old 01-23-2019, 07:26 PM
007JB's Avatar
SLI94RAGM
thanks. I called my vendor, they're gonna do special price for me $145, because it's my car. how many month warranty they gave you on that?
Old 01-23-2019, 07:35 PM
I believe it’s 48m, but I could be wrong. It will last forever though, my car lives on a CTEK charger.
Old 01-23-2019, 08:11 PM
SheriffDep's Avatar
SLI94RAGM
I have the same battery. There is a plug on the right side, and a vent tube plugs into the left side and then drops out the bottom of the vehicle. MAYBE this is not a vent tube and just some tube for something. But I have the same battery as you.
Old 01-23-2019, 08:17 PM
007JB's Avatar
I believe they are all USA made. I'm gonna order one for my 2013 Vantage. It's time. thanks for info.
Old 01-24-2019, 04:49 AM
MRCW's Avatar
Group buy?
Old 01-24-2019, 10:48 AM
RolexDaytona1's Avatar
RolexDaytona1 has a spectacular aura aboutRolexDaytona1 has a spectacular aura aboutRolexDaytona1 has a spectacular aura about
Check the date code!
I inadvertently bought a Duracell (as above) but it had been sitting too long on the shelf and 'should' have been returned to the mfg had anyone noticed...
I wound up with a dead/faulty battery 2 months later and had to do another (never enjoyable) battery swapout. They acknowledged it was the reseller's fault. But a lot of time wasted on my end.
2nd one has been fine.
Old 01-24-2019, 12:15 PM
davidm17's Avatar
davidm17 is on a distinguished road
The Bosch AGM I put in most definitely has a vent tube.
I mentioned this in one of your other threads, but 2013+ (maybe 2012.5+?) cars use a different size than prior cars so make sure you are getting the correct size.
Old 01-24-2019, 12:25 PM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
Many AGM batteries have vent ports. All AGM batteries CAN vent hydrogen if charged at a excessive voltage levels, even the unvented ones.
Old 01-24-2019, 03:59 PM
OK...not sure we have the same battery. I literally just went back out to car, took all the packing and carpet out to double check i'm not losing my mind and there is not a vent tube.
MY Duracell battery, absolutely does NOT have a vent tube anywhere at all. While i'm not debating if AGM batteries have vents or not....11 bikes in my garage, my RAM 3500 truck (which has 2 batteries) and now my Aston all have AGM batteries and NONE of them have vent tubes.
Not sure what all that means, but at least that's a data point.
Cheers,
Matt.
Quick Reply: AGM or non AGM battery
