Brembo
Any thoughts on using Brembo 4 brake fluid?
I'm sure if it's brembo it's great, but if you are purchasing rather go Motul RBF 660 and be done.
Depends on how you use the car. No need for high-temp brake fluid unless you are going to be on a track. A DOT4 fluid would be just fine for a street driven car, whether Brembo brand or some other brand.
I agree with matching the tool to the task. If you're not tracking the car, any DOT 4 is fine. If you are tracking the car, RBF660 is great but I'm seeing a lot of experienced track people recommending Castrol SRF above all else (when it's time to change out my fluid, I'll give it a shot).
RBF 660 is compatible with all seals and no risk of seal degradation....forget about tracking the friken car .....dot 5 is simply a no go and will cause you trouble later on don't use silecon unless you have rebuilt the entire system.
besides we are not talking about a lot of cash here ....life is simple ....always shag the thinest chick, or the wealthiest, put on the best rubber you can afford ...on the car, use the best lube, that leaves no trace of malice or bad smell....it's a frikken Aston shell out or get an Audi |
I use Castrol SRF in everything I own.
Originally Posted by captain Greg
(Post 4779127)
besides we are not talking about a lot of cash here ....life is simple ....always shag the thinest chick, or the wealthiest, put on the best rubber you can afford ...on the car, use the best lube, that leaves no trace of malice or bad smell....it's a frikken Aston shell out or get an Audi I don't see anybody saying anything about DOT 5 fluids... If you think my language suggested Castrol SRF was DOT 5, it's not... it's DOT 4. I was simply explaining that particularly high temp fluids only matter in racing applications, and that any DOT 4 fluid will serve street use just fine. |
Originally Posted by Mathman85
(Post 4779442)
I don't see anybody saying anything about DOT 5 fluids... If you think my language suggested Castrol SRF was DOT 5, it's not... it's DOT 4. I was simply explaining that particularly high temp fluids only matter in racing applications, and that any DOT 4 fluid will serve street use just fine. as rule I don't track much, but for wot it's worth even on the road my RBF 660 discoloration is noticeable in the fluid reservoir on my bikes ...so why would I ever go to a lower end product when the top of the range takes strain ? While I appreciate that discoloration is no thermometer of fluid performance or longevity I personally don't enjoy dark brake/clutch fluid and will always try and offer my machine the best chemical engineering available ......like going to a dentist I seldom chose a man who is offering the budget service brembo make breaks systems I doubt that they have the infrastructure or budget to develop fluids to the extent companies like motul or Castrol who only make fluids do? In saying a product is fine for the road?.. well on Wednesday I took my Aston out on a road run ....I wrung its neck in every gear for almost three hours non stop hitting the guv too many times to recall during up shifts I braked for slow traffic and braked hard to avoid cars that were slow or coming onto highways i braked many times from speeds of over 245km per hour down to 30km per hour the abs was going mad and the smell of the EBC red stuff was pronounced in the cabin at times .....would I have felt comfortable with a cheaper fluid in my break system, after all I was on the road and I am willing to bet my car had a harder time in that three hours than a few sets of 10 laps at a track day! So my thinking is since fluid prices are negligible between RBF 660 and anything else why bother with anything else? I have no dog in this race and no commitment to Motul, I just know from being a petrol head for almost 50 years there is little to touch it from a performance perspective so get hold of redpants and secure some Motul while he still has it, fortunately for us Motul is easily Available here locally im TIBA on this one |
I'd be surprised if your spirited street driving got the fluid temps anywhere near the DOT 4 standard for boiling points, but okay. lol
I do support buying good fluids, obviously, but the higher boiling point of top-end fluids (like RBF660 and SRF) is the only reason they cost more. My bigger point, ultimately, is that any DOT 4 fluid will safely stop the car in street conditions (that's what the standards are for), but if you do far more aggressive braking (and really, only if you do), you need fluid with a higher boiling point. |
Originally Posted by horsepowerfarm
(Post 4779151)
How many times has anyone boiled a vantages brake fluid while on the street? |
(Post 4779456)
I do support buying good fluids, obviously, but the higher boiling point of top-end fluids (like RBF660 and SRF) is the only reason they cost more. My bigger point, ultimately, is that any DOT 4 fluid will safely stop the car in street conditions (that's what the standards are for), but if you do far more aggressive braking (and really, only if you do), you need fluid with a higher boiling point. Imho it doesn’t matter how “crazy road racer madness” you are doing, you can’t get enough repetitive aggressive stops in to heat the fluid to failure past a normal dot 4. I get it, it’s a few bucks more, go ahead and splurge, but let’s not confuse the stress on fluid of any all out 20 min track session with massive amounts of 100% brake from triple digits to zero in very short time increments with anything that is reasonable or feasible no matter how much disregard one has for street rules. |
