Alternator Replacement
Old Jul 15, 2019 | 10:35 AM
oo7's Avatar
oo7
oo7 is just really niceoo7 is just really niceoo7 is just really niceoo7 is just really nice
2007 V8V Alternator failed. 2005 -2006 Ford thunderbird is replacement part. It would be great to start a thread to aggregate compatable/replacement parts with parts number equivalents.
Old Jul 15, 2019 | 11:40 AM
charliefore's Avatar
5 Year Member
charliefore is infamous around these parts
Alternator does not come out without removal of subframe. Main bolt doesn't back out thru subframe. Have to section bolt. Very difficult access. Best of luck!
Old Jul 15, 2019 | 01:49 PM
oo7's Avatar
oo7
Will post how it goes, was aware the oil tank must be moved.
Old Jul 15, 2019 | 02:09 PM
5 Year Member
Replaced on 2007 couple years ago with 95k miles at that time. I had to beat alternator out of place with breaker bar and mini sledge. Once new alt was in place could not budge it. Because of subframe could not use main bolt, think I used 3/8 threaded rod which would fit into opening of subframe then place nuts on each end. 5/8 was too large and wouldn't fit into slot on subframe.
Old Jul 19, 2019 | 08:03 AM
oo7's Avatar
oo7
Did not encounter issues of previous poster thankfully. Not as simple or straightforward as one would think. Had a more robust unit discovered, I would have installed it just to not have to go through it again.
Old Jul 19, 2019 | 08:06 AM
BMW-North's Avatar
BMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant future
Good to know - the workshop manual procedure didn't seem to indicate any of the issues mentioned.
PG_Porsche
May 18, 2017 07:52 AM
timccloud
Aug 3, 2014 08:48 AM
carcrazee
Aug 31, 2005 02:44 PM
Greyghost
Jun 22, 2004 01:21 AM
