V8 vantage hood adjustment
Old Mar 28, 2020 | 12:44 PM
mthdr's Avatar
mthdr is infamous around these parts
I have read the thread linked in the FAQ about adjusting the striker. From what I understood is the entire front of the hood was closing a bit low.
On mine, only the left side is a bit low (3mm), but it's the entire left side; the hood is about 2mm lower than the fender/wing along the entire length. The workshop manual in the section about refitting the hood makes mention of shims where the hinge mounts to the frame. I'm surmising that more shims are needed. The manual states to have the fender/wing installed and adjust the shimming, though it does state that removing the fender/wing is one of the first tasks when doing anything with the hood. Is it possible to get to the hinge shims by removing the inner fender/wing liner?
Old Mar 29, 2020 | 10:52 AM
Prefurbia's Avatar
Prefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond repute
Be careful - the hood latch adjustment is something noted to do at annual inspections - a local non-Aston dealer was selling a used 2008 Vantage and in the test drive the hood flew open - an $8,000 repair, that's how I found out the hood latch is pretty important to get right.
Old Mar 29, 2020 | 11:39 AM
M I Six's Avatar
M I Six has much to be proud ofM I Six has much to be proud ofM I Six has much to be proud ofM I Six has much to be proud ofM I Six has much to be proud ofM I Six has much to be proud ofM I Six has much to be proud ofM I Six has much to be proud of
Almost lost my hood as well. Luckily the dash has a warning light and the audible alarm will not go away until you stop and fix the hood. Hood was lifting quiet a bit at only 30mph, can only imagine it popping at 50mph+.
Old Mar 29, 2020 | 12:36 PM
mackorbuddy's Avatar
mackorbuddy is infamous around these parts
The fenders are adjustable as well, you may want to consider bringing the one fender down lower. Open the hood and take a look at the bolts along the fender. The mounting points underneath the fender can be adjusted higher or lower by turning them.
Old Mar 29, 2020 | 02:10 PM
mthdr's Avatar
The hood latch is fine, it closes firmly when letting it drop from 6 inches or so. I'll look at adjusting the fender, but I think that it already lines up correctly with the other panels.
Thanks.
cetro
Jan 26, 2020 11:45 AM
BauerR
Jul 26, 2017 05:24 AM
rscultho
Sep 24, 2014 04:37 AM
midwestamv8
Sep 6, 2014 11:55 AM
jjparkusa
Mar 30, 2008 05:56 PM
