Help solve a brake mystery
Old May 3, 2020 | 09:59 AM
deckman's Avatar
I bought my 2013 V8V four years ago from the original owner when it had 4,500 miles. This weekend I changed the brake pad with Porterfeld RS-4's I replaced them because the rears were getting thin. That was the first thing that struck me as odd, why would the rears be going before the fronts? That's backward. When changing them, the front had plenty of material left and was a Brembo pad. The thin rears were RS-4's, so not original. How did it get this way? Someone replaced the rears within 4,500 miles? So this is the third set of rears in 16k miles.
Old May 3, 2020 | 04:26 PM
Graze's Avatar
5 Year Member
Graze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to all
Think traction control!
that uses the rears so every time you wiggle the rear end your rear brakes get a serious work out
Graze
Old May 6, 2020 | 08:01 AM
Calcifer33's Avatar
Calcifer33 is infamous around these parts
Not sure of the V8V but in the DB9 manual, it specifically states that the rears will wear faster than the fronts.
Third set of rears in 16k seems high to me, but I'm not as knowledgeable as many others on this forum.
Old May 7, 2020 | 04:56 PM
captain Greg's Avatar
captain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to behold
Graze
spot on, I have had this as well and also was puzzled by rear wear over front
Old May 8, 2020 | 03:42 AM
MRCW's Avatar
Graze
makes sense...I was surprised at how worn my rear pads were when I replaced all fours a couple months ago... since I started with 4 fresh sets... it will be good way to keep track of the wear.
Old May 8, 2020 | 11:20 AM
deckman's Avatar
Thanks. Still a mystery to me that the rears were replaced in under 4,500 by the previous owner. Maybe that explains his comment when turning the car over to me that he wanted something that would do a better job of pushing him back into his seat.
Old May 8, 2020 | 12:10 PM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
Might have had brake squeal issues on the rears.
Old May 8, 2020 | 12:12 PM
Denny 6.53's Avatar
Denny 6.53 is infamous around these parts
Same reason that the rear tires wear faster than the fronts?
Old May 8, 2020 | 01:22 PM
J doubleU's Avatar
OEM rear pads start out life @ 7mm of material. Not much meat considering the wear indicator comes on around 2.5mm remaining.
rolltide0323
Feb 19, 2018 11:12 AM
Wildcat1212
Dec 23, 2013 02:00 PM
Fubar
Sep 19, 2013 09:04 PM
artlu
Oct 4, 2009 07:50 PM
Targa Tim
Cayenne 955/957
Apr 13, 2009 02:07 PM
