Car won't start - 09 V8V 6MT
Old Jul 11, 2020 | 05:24 PM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
Originally Posted by blue2000s
I still think it is the battery. Do you have another car that you can use to try to jump start the car?
+1.
FWIW, My battery reads 13.8V prior to start, drops to 10.9 when cranking and backup to 13.9 when idling.
Old Jul 11, 2020 | 05:38 PM
07sportspack's Avatar
07sportspack has a spectacular aura about07sportspack has a spectacular aura about
I would remove the battery and take it to the store you purchased it. At 16 months it should have warranty, Have the store check it out. They should replace it if you have a big draw down in voltage The cranking amps certainly would be severely effected too. The potential bad battery/connection question must be cleared up. Good luck
Old Jul 11, 2020 | 06:05 PM
Hedged's Avatar
Hedged is a jewel in the roughHedged is a jewel in the roughHedged is a jewel in the rough
I have a stick as well and on occasion it will do what you describe and then will start if I push down harder than normal on the clutch pedal during startup. May not solve your problem but has worked for me FWIW.
Old Jul 11, 2020 | 07:05 PM
mthdr's Avatar
mthdr is infamous around these parts
Originally Posted by Kalepsis
I doubt the clutch position sensor is bad, since the engine start light goes red when the clutch is depressed.
Thanks for the window calibration procedure, it worked.
I used my multimeter to check the battery voltage. 12.2V at rest, 11.8V with the start button pressed and held. Also, the manufacture date on the battery is March of 2019, so it's only 16 months old. And the leads on the posts look brand new, not a speck of corrosion.
There's got to be something else. The starter solenoid clicks but the starter itself doesn't even make an attempt to turn the flywheel.
I plugged in my bluetooth OBD reader and looked at some of the live data. It confirmed the voltage to the ECU was 12.22 at rest, 11.78 on start attempt.
I didn't see anything weird in any of the other parameters.
Mine does something similar with the plastic keys (takes several attempts before it will throw the starter), but is fine with the glass key.
Old Jul 11, 2020 | 07:14 PM
J doubleU's Avatar
Do you live on a hill? Try a bump start.
Old Jul 12, 2020 | 12:33 AM
Kalepsis's Avatar
5 Year Member
Kalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to all
You guys were right. Apparently what it needed was a set of jumper cables and a 98 Volvo V70. I hooked up to the jump points, let the Turbobrick run for a few minutes, and the Vantage started. Laboriously.
It had the red triangle and "Electrical System Service Urgent", so I let it idle for ten minutes, then took it for a 25-mile drive and the warnings went away after the first mile or so. I kept the bluetooth OBD reader in so I could monitor the live voltage level while driving and it never dropped below 14. So the alternator is good.
It's just weird that a battery would go bad when it's not even 18 months old, and I drive the car at least once a week. I'll see what its charge is tomorrow evening, after it sits for a day. In the meantime, I'll order a battery tender.
Old Jul 12, 2020 | 06:16 AM
Jack1954's Avatar
Jack1954 is infamous around these parts
Glad you got it started.
Old Jul 12, 2020 | 09:01 AM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
Excellent. Does it have a warranty remaining? Batteries can sit on a shelf at the store for a long time so they may not be good when you get it. I try to make sure that I know the date of manufacture when I buy one.
Old Jul 12, 2020 | 09:22 AM
J doubleU's Avatar
If the battery has 1 bad cell, that could be your issue. Have the battery tested or replaced. Batter tender isn't going to remedy your problem.
Old Jul 12, 2020 | 02:30 PM
AstonCarma's Avatar
5 Year Member
AstonCarma is infamous around these parts
Yep. Even though you got it started, you may not be out of the water just yet. If you remove the battery from the vehicle and bring it to an Autozone, they can put the battery under load and see how it performs. Obviously you can just keep driving it right now and see if any issues come back and if they don't, the car's probably fine.
There are a lot of smart guys who know about desulfating batteries though and swear by the methods, though I don't think in your timeframe that would be the issue. I still strongly recommend a battery tender no matter what though, as sometimes even two weeks without driving can render our cars inoperable.
Old Jul 12, 2020 | 03:26 PM
blue2000s's Avatar
You don't have to take the battery out of the car for the store to test it. But I would make it accessible so they can pull off the + terminal for testing.
Old Jul 12, 2020 | 07:06 PM
sonies's Avatar
5 Year Member
sonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud of
(I tried to do a search here, but the system just kept bringing up literally every thread on the whole board because of its common word filters)
I drove the car yesterday for about 25 miles, no problems, nothing out of the ordinary. Went to start it today and all I got was a nice, loud click. No attempt to turn the engine over. No errors, no CEL, nothing.
So I'm thinking it's either the battery or the starter. I tried it with the headlights on and nothing even dimmed while I was holding the button, so I don't think the battery is bad.
Has anyone experienced this issue before? Do any of you have a trickle charger I can borrow?
Thanks in advance.
try a few more times, sometimes the key just doesn't work
Old Jul 15, 2020 | 02:17 AM
Kalepsis's Avatar
5 Year Member
Update: I've driven the car a couple times the last two days since jumping it with my Volvo. It starts, but the battery is obviously not healthy, it causes a stutter when starting the car. So I will be replacing the battery.
On RockAuto there's an Exide MXH8L549 AGM battery for $166 with a 4-year free replacement warranty. Any reason not to use this brand?
If others have had problems with Exide, I could always get the Motorcraft battery for $200.
Old Jul 15, 2020 | 01:08 PM
E30 Racer's Avatar
E30 Racer is infamous around these parts
I bought a Duracell H8 AGM from Sam's Club a few weeks ago for $180. What sold me what that it's made by East Penn/Deka, which is a highly regarded manufacturer.
Old Jul 15, 2020 | 01:12 PM
Kalepsis's Avatar
5 Year Member
There's a Deka battery on RockAuto, too, for about $180. How's their warranty?
