I was installing an Apple Carplay-Android Auto box in my 2017 DB11 (LHD). When I re attached the battery, I heard a pop and the lower parts of the center stack do not operate or light up. The problem may be in a 16 fuse panel that appears to be near the driver inside the car (panel B I the attachment). I'm trying to figure out exactly where it is before I start tearing things apart. Anyone have any suggestions?
For anyone who may need to deal with this in the future. Fuse panel B is locatedlunder the panel just inside the door. The one with the black rubber grommet to seal where air moves from the dash to the door.
Thanks! I know this thread was awhile back but I am looking to check those fuses now. I have the single day subscription to the Aston service manuals but even with that diagram it wasn’t clear where that fuse box was.
I have the info on removing that panel from the manual but was there anything you can mention about removing it, was it straight forward? Any gotchas?
That’s a scary panel to remove, but I suspect I have a blown fuse and all the others are good.
