2009 Vantage - crank but wont start
Old Jun 6, 2022 | 04:55 AM
forumoto's Avatar
forumoto is infamous around these parts
2009 Aston martin, clutch and pressure plate was replaced by a shop, after the replacement car wont start, it crank already but it wont start, no fire on the coil nor injection, but car crank, before the replacement of the clutch and pressure plate, car was starting. i have tried to find out by them if they have accidentally got something wrong done while doing the installation but they could not say anything...
well could someone help with the location of th crank and cam sensors
Old Jun 6, 2022 | 06:16 AM
J doubleU's Avatar
Did they change the flywheel? If it was not installed correctly the car doesn't know crankshaft position and you will have those symptoms.
Old Jun 6, 2022 | 06:20 AM
forumoto's Avatar
well they said they only change pressure plate and disc, I have tried my best to get access to schematic which shows where the crank sensor could be, I don’t know if it is on the bell housing sensing the flex plate or it is inside the engine or the pulley front area, I don’t know, this car their schematics are hard to find.
but am very grateful for taking your time to read my post. Thank you, if you have some informations to share, I will welcome it.
please are you a tech guy on this particular make
Old Jun 6, 2022 | 07:17 AM
J doubleU's Avatar
Crankshaft speed sensor in at the back side of the engine at the bottom center.
Old Jun 6, 2022 | 07:21 AM
forumoto's Avatar
so it means It not closure to where the bell housing is, some cars have theirs in the engine while some have it at the front of the front pulley and others too on the bell housing where the flywheel is… do you think where it is now, removal of the transmission could have had effect on it, even though they re saying no fault code when the engine crank,
Old Jun 6, 2022 | 09:21 AM
61mga's Avatar
61mga is infamous around these parts
i would be all over my OBDII reader searching for codes, before even thinking about getting under the car.
Old Jun 6, 2022 | 09:23 AM
MRCW's Avatar
How did you pick up the car after the clutch service? Is it still at the shop?
Also if it's an ASM there is a clutch position sensor as well.
I have a 2009 Vantage Workshop manual. It's 115 meg file if you have a way to receive it I could send it to you. They are also on line
Old Jun 6, 2022 | 09:26 AM
forumoto's Avatar
I have am yet to get the car, it will need to be tow, because it is not starting, I asked several
questions from where the car is and all the information am discussing here were provided base on the questions I asked , so personally am yet to have the car tow to me, for scan report and live data analysis,
Old Jun 27, 2022 | 09:51 PM
JKhlok's Avatar
JKhlok is infamous around these parts
Did you ever get this resolved?
Old Jul 25, 2022 | 08:28 AM
domibln's Avatar
domibln is infamous around these parts
If It's an ASM / Sportshift gearbox, it's necessary to run the adaption procedure after clutch change in order to teach the new clutch kiss point.
Old Jul 25, 2022 | 09:50 AM
SLVRon's Avatar
5 Year Member
SLVRon is infamous around these parts
Might this be as simple as the switch under the brake pedal? I had a similar problem with the switch under the clutch pedal in a 6MT car some years ago, which would prevent it starting.
bavarianstance
Jun 29, 2022 12:10 PM
blue2000s
Feb 16, 2022 09:55 AM
rocketboots999
Dec 27, 2021 03:49 AM
Prefurbia
Aug 26, 2021 11:50 AM
JimB_MN
Oct 11, 2011 08:34 AM
