Thoughts on serpentine belt/2 pulleys replacement
Old Aug 28, 2024 | 06:32 AM
sweet991S's Avatar
5 Year Member
sweet991S
Good Morning all-
I have a well-sorted (finally!) 2010 V8V Roadster 6 sp manual with a recently inspected (and original to the car we think) serpentine belt. My mechanic, with 20+ yrs of experience and whom i trust 110%, this past week examined my S belt and stated that it looks in very good shape with no cracks or other signs of deterioration. While the AM maintenance schedule indicates replacement at the 10 year mark, I am planning to wait longer, as I really don't think I want to "fix something that isn't broken". I just received the orig AM belt and the 2 pullies suggested by Chris at Scuderia Parts. (BTW< they are SUPER-easy to deal with!). The Dealer sez it's 2.5 hrs at 315$/hr.......but it's straightforward mechanical work (no resetting of anything electronic).
Other than a slight whine, what symptoms should I be on the lookout for re: the belt starting to fail? TIA as always....!
Old Aug 28, 2024 | 07:46 AM
Hedged's Avatar
Hedged is a jewel in the roughHedged is a jewel in the roughHedged is a jewel in the rough
If you have confirmed 100% that you have both the updated belt and pulley on your car.....whine can come from either belt wear (usual suspect is old style belt and/or pulley), fluid leaking onto belt from one of the many sources at engine front, or improper tension (least likely given the nature of the tensioner). Belt could also be age worn w/o obvious visible wear.
Old Aug 28, 2024 | 10:45 AM
sweet991S's Avatar
5 Year Member
sweet991S
Thank you Hedged.....the older-design was associated with the 4.3 engines, not the 4.7's AS I understand it. Appreciate your insights.
Old Aug 28, 2024 | 02:23 PM
Hedged's Avatar
Even if you are the original owner it is possible that a respected Aston dealer or independent shop may have mistakenly installed the wrong belt at some point. I speak from experience on this.
Old Aug 28, 2024 | 03:32 PM
sweet991S's Avatar
5 Year Member
sweet991S
Could be - thanks!
Old Aug 28, 2024 | 05:06 PM
ragingfool35's Avatar
ragingfool35 is infamous around these parts
once in the air and tray removed, its a 20 minute job alone. buy this, print the belt routing diagram from Redpants and watch the Redpants video. i just did the belt job for the first time in May. no hassle at all. i didn't replace pulleys though but don't see much time there
Amazon Amazon
Old Aug 29, 2024 | 05:56 AM
sweet991S's Avatar
5 Year Member
sweet991S
Thank you RF35! My local Tech is concerned that because he doesn't have access to the latest AM software/itty bitty parts that could (conceivably) break, he's reluctant to do the work. I therefore sent him your comment and suggested he watch the RedPants video....!
Thnks again!!
ciaka
Cayenne 955/957
Apr 25, 2020 10:19 PM
elite1
Oct 21, 2014 09:21 PM
cmoore1
Cayenne 955/957
Jun 23, 2014 07:54 PM
soccerTOOLsu
Apr 5, 2013 11:58 AM
kirk911tt
Feb 15, 2009 02:54 PM
