1981 AMC Jeep CJ-7
1981 AMC Jeep CJ-7
Year: 1981
Make: Jeep
Model: CJ7
Price: $17499
Mileage: 70000
Color: Red
Location (State): TX
Transmission: Manual
Drivetrain: 4WD & AWD
Excellent Condition NO RUST OR ROT.
The Jeep was taken down to the frame. Frame was powder coated. Body has been repaired and there is no rust to be found. Four coats of U-Pol Raptor Bedliner put in tub. 90% Belted Mickey Thompson Baja's in 31x13.50x15 on Alcoa 15x10 rims.
Disc Brakes on all corners. Rebuilt and excellent shape Dana 30 front axle and AMC 20 rear. T-176 4 speed tranny is VERY strong. Upgraded clutch. Dana 300 transfer case works perfect.
Chevy 4 Bolt Main Small Block 350 stroked to 383, with 450HP/500TQ. Forged Eagle Rod's and Piston's. Molly Rings. Edelbrock Air Gap Intake. MSD Pro Billet Distributor with MSD 6AL Ignition Box. ProComp "Red's" Billet Roller Rockers. Doug Herbert Solid Roller Cam(High Torque). Solid lifters. Trickflow G2 "Twisted Wedge" high flow aluminum heads. AVCO 5 micron Fuel Filter. 10.1 Compression. 93 Octane or higher ONLY. Engine was Balanced and Blueprinted and the entire rotating assembly is forged and rock solid. Quadrajet 750 carb. Starts without touching the gas.
All new or like new dash gauges and lighting. STOCK DASH! Smittybilt locking console with space for radio. Brand New center gauge cluster and odometer. Fuel system is new from tank to carb. Heater Box reconditioned and upgraded blower motor. Blows hard and hot. All cables and ***** work as they should. New roll bar cover. Brand New Bestop Super Top in black denim. Windows are perfect condition. Comes with old set of hard doors that need work but for $500 should be able to get to like new condition.
If you are looking for a Jeep that is NOT a project and want to stick it in the Garage and drive it on weekends without any headache or use it as a reliable daily driver like I have been doing, then this is the Jeep for you. It's done! You can putt around at 1750 RPM nice and slow and smooth or floor it and instantly pass anything on the road. Great throttle response and driveability.
Just bought a new 2011 Ford F250 so need to sell to make room at house.
Contact Ryan on my cell at 71Three 29One 24OneOne.
vpr80
03-06-2021 12:11 PM
