2007 911 Turbo - Manual - Ceramics
Year: 2007
Make: Porsche
Model: 911
Price: $65000
Mileage: 63500
Color: Black
Location (State): CA
Transmission: Manual
Drivetrain: 4WD & AWD
The car's asking price is $65,000 firm.
Please let me know if there are any questions. Thank you!
The car's build sheet can be seen below:
Build Sheet
MSRP: $144,533
Axel-Differential Lock Rear
Heated Front Seats
Ceramic Composite Brakes - PCCB
Parking Assist System
Sport Chrono Package
Module for Telephone PCM
Remote CD Changer (6 Disc)
Black
Black Full Leather
Storage Compartment Lid with Model Logo
Gear Lever/Handbrake Aluminum/Leather
Black Mats - Porsche Lettering
Adaptive Sport Seats
Standard Rocker Panels Painted
Sport Shifter
Rear Center Console Leather
Thicker Steering Wheel Leather
Porsche Crest in Headrest
Aftermarket items:
Hardwired Valentine V1 Radar in the rear mirror
Cobb AccessPort with Stage 2 tune
Sachs 2.5 Clutch
Speedtech Catless 3.0" X-pipe exhaust
H&R Springs
Walk Around Video:
I never ran a DME report on the car when I went to purchase it, nor the previous owners.
Regardless, I know there seems to always be lot of focus on it so I'm happy to go get one at the potential buyers expense.
Some additional details based upon recent questions
Owner History
Per the CarFax report I did for the car when I was purchasing it, I would be considered the 6th owner, however based upon the Owner History in CarFax, 3 of the owners look to be car dealerships. Feel free to run your own CarFax, but here are the owner details per my report.
- Owner 1 - 4/13/2006 to 4/7/2010
Vehicle was registered in New Jersey however service records showed to be at The Auto Gallery in Woodland Hills, CA
- Owner 2 - 9/20/2010 to 9/21/2010
Vehicle was registered in Arizona and then offered for sale the next day
- Owner 3 - 11/24/2010 - 2/1/2014
Vehicle was registered in Arizona with service records tied to Porsche North Scottsdale
- Owner 4 - 3/20/2014 - 9/23/2015
Vehicle was registered in California with service records tied to The Auto Gallery in Woodland Hills, CA
- Owner 5 - 9/23/2015 - March 2017
- Owner 6 - March 2017 - Present
My current ownership
Recent Maintenance History with Receipts
- Miles: 56,834 - Transmission/Clutch - Sachs 2.5 Clutch with new OEM flywheel
Customer reported clutch is slipping
Verified Customer's concern, clutch would slip under load
Per request, removed transmission for inspection and found clutch assembly worn out and flywheel has hot spots
Recommend flywheel and clutch assembly to be replaced
Per request, removed and replaced clutch assembly provided by customer. Removed flywheel and replaced with OEM OES flywheel
Re-installed transmission. Bled clutch slave cylinder. Filled and bled cooling system
Road test vehicle to verify repair
- Miles: 59,958 - Major 60K Service
Customer requested major service
Per request, performed major service. Changed engine oil; oil filter; filter o-ring and crush washers
Removed and replaced engine air filter. Removed and replaced in-cabin pollen filter
Removed and replaced all spark plugs. Applied fuel additive and windshield washer solvent
Performed system diagnosis, read out any faults present in DME.
Inspected all under-body panels - ensure all are secured and tight. Passenger side front wheel liner damaged and spoiler was gone.
Inspected coolant level and antifreeze condition. Inspected radiators for blockage or external debris
Inspected brake hoses and lines. Inspected all drive shaft boots for leaks and wear. Checked out ok.
Inspected drive belt condition, serpentine belt need replacement. Serpentine belt replaced. Also removed and replaced fuel filter.
Checked all drains for debris and blockage. Checked out ok.
Checked all doors; lid locks and hood latches for proper function. Checked out ok.
Checked horn; vehicle electrical including turn signal and headlights functionality. Checked out ok.
Checked vehicle warning lights and battery condition. Checked out ok.
Found front brake pads at 6mm remaining and rear pads at 7mm remaining
Found front tires at 7/32" tread depth and rear tires at 5/32" tread depth
- Miles: 61,591 - Exhaust System Installed - Speedtech Catless 3.0 X-Pipe
Exhaust system installed
Replaced all gaskets
Replaced exhaust studs and nuts
Purchased and replaced all front and rear O2 sensors
- Miles: 62,000 - Oil Change
- Miles: 62,625 - New Battery - Bosch Platinum Series
- Miles: 62,745 - New Front & Rear Brake Pads, Sensors & Caliper Bolts
People have also asked about rock chips so I've attached some new pictures below
Owner History
