Covercraft Weather Shield Audi A4/S4 car cover
Mint conditioncovercraft Weathershield Car Cover. It was only used for two months and includes bag for the cover. WeatherShield®, uses a patented immersion process that uses heat and pressure to permanently encapsulate the fibers of the fabric to shed moisture and block dust, dirt, bird droppings, tree sap and grime. This encapsulation process places an ultra-thin coating around the fabric fibers and at the same time creates a durable, breathable barrier within the woven polyester fabric to complete the high performance finish process. Unlike traditional coatings and laminations that just protect one side of the fabric WeatherShield® places long-lasting protective formulas inside the fabric. The result is a fabric that provides maximum protection, but isn't bulky and hard to store. Using this immersion encapsulation technology we've created the ultimate car cover...and we named it WeatherShield because no other fabric has every shielded your car or truck from the elements like this one! This magnified photo gives you an idea how the immersion encapsulation coats the fibers and fills the voids between the threads with a breathable barrier to assure any moisture that does get under the cover (or heat on a hot summer day) can easily escape through the fabric. During evaporation moisture turns into vapor and the vapor is smaller than water droplets so it easily transfers through the fabric. The base, high-strength, polyester fabric is naturally UV resistant, but we've added UV inhibitors to the polymers to help slow-down the degradation that occurs naturally on anything exposed to sun for an extended period of time. Weatherproof - Fabric sheds water as soon as it hits the cover. Superior Dry Time
$150.00 Thanks
Arnie
$150.00 Thanks
Arnie
PorscheEnthusiast
Nov 13, 2015 02:23 PM
