Product Announcement: JRZ RS Pro Silent Edition, Forged Performance Exclusive Dealer
We are pleased to announce that JRZ Suspension Engineering has appointed Forged Performance, LLC as the exclusive North American Distributor for the JRZ RS Pro Silent Edition suspension system. Forged Performance has been partnering with JRZ since 2008 and through extensive technical discussion we've brought to market the finest dual purpose coil over system.
As many of you will recall, many of the fastest GT-R's are equipped with JRZ coilovers which have resulted in many track records and podium finishes all over the world. JRZ is also a top supplier of suspension systems to numerous professional racing organizations including ALMS, Grand Am, and SCCA. Using feedback from our client base, we wanted to introduce a coilover system that was poised on track, but near silent on the street. Solid top mounts can create some noise that is not desirable for street use. The JRZ RS Pro Silent Edition combines the best features of a street and race coilover system. It uses the same motorsports pro body as the race shock, while retaining the top OEM mount. Valving is optimized to match the unique characteristics of an OEM rubber top mount. This results in superb on track handling, while keeping the system very quiet and compliant on the street. • 22mm rod strut, 16mm rod damper • Mono tube • Double Adjustable Rebound and Compression • Precision CNC Machined Top Mount Adapter • Adjustable gas pressure • Piston sized for high performance • Street compliance valving • Precise canister • Large adjustment range • Fixed hoses for easy mounting • Steel piggyback The RS Pro has a remote canister with a progressive blow off system. Progressive blow off allows for a stiff compression valving while maintaining smooth response. The result is a damper that provides ultra solid platform with smooth bump compliance. The JRZ standard large 22mm piston rod works in concert to maximize blow off valve response to great chassis control without using a high spring rate in strut applications. In damper applications the piston rod diameter is 16mm to achieve a balance between ride and control. The monotube design makes use of our unique RS Pro piston. By moving more fluid than our standard clubsport damper, the RS Pro achieves a higher level of chassis control. To customize track to track setups and tailor the chassis to the JRZ RS Pro has an extra large adjustment range. Each adjustment is designed to be an even step giving you predictability when making changes. JRZ clubsport dampers are designed to give the chassis tuner ultimate control. Benefits The design of the RS Pro takes you to the next level. Stiffer cars with higher levels of power demand the control JRZ can supplies. With the control of gas pressure charge as well and compression and rebound adjustments, the RS Pro will get the most out of your high performance car. The JRZ RS Pro is shipped as a bolt on kit with installation instructions and always comes with our world renowned personal service JRZ. Recommended applications: • Highly modified Street/DE • Experienced Club Racing Recommended Spring Rate for OEM weight car: 1000lb front 800lb rear. Spring rate is custom tailored to each specific client based on intended usage, tire choice, and many other factors. Compression and Rebounds controls will be pre-adjusted for faster setup time. MSRP: $5530 Contact a Forged Performance sales representative for further information, or to place an order. http://onfinite.com/libraries/1580052/074.jpg http://onfinite.com/libraries/1580053/72c.jpg http://onfinite.com/libraries/1580649/178.jpg Check out these Reviews on The JRZ RS PRO Silent's JRZ RS Pro Silents - Install and Review JRZ RS Pro Silent - Track Tested at Sebring Kislik review on JRZ RS Pro Silent Forged Performance is the Exclusive North American Distributor for the JRZ RS Pro Silent Edition. To order your set of JRZ coilovers pleaser call the Forged Performance sales staff for immediate assistance. We look forward to working with you. Sharif |
Finally a streetable product from JRZ. That's great news.
How many U.S. Distributors does JRZ have? I thought TPC and TRG were the exclusive U.S. Distributors for JRZ? |
They may have different distributors for their race markets. I do know are many dealers and distributors in the retail space. We inked an exclusive agreement on the silent editions only but we carry all JRZ products across the various lines.
These have proved to be one of the best selling JRZ's for GT-Rs. PM or call us for more information!
Ultimate handling without sacrificing ride quality. Get the most popular JRZ suspension for the Nissan GT-R from Forged Performance.
Tray |
This is the best street coilover on the market. You won't find a better option anywhere :)
Give us a call today for you own set of JRZ Silent Coilovers.
Tray |
Looking for an amazing coilover soultion for the street and track?
The JRZ Silent Edition is your solution and we're the exclusive distributor! Call or PM us for great pricing! |
These are the best multipurpose coilover available!
Get your JRZ RS Pros exclusively at Forged Performance!
Call or PM for the BEST pricing! Thanks, Decker |
Don't settle for anything less!
Give us a call today for the best possible prices, and service. Forged Performance is here to help you. We look forward to working with you!
Tray 770-792-0202 |
Are you really going to bump this up almost everyday?
We have these in stock ready to ship :)
