FS: Set of (4) 996/997 GT3 Inner Monoball Pivot Points
Set of (4) 996/997 GT3 Inner Monoball Pivot Points. The monoball cartridges were installed into NEW factory rubber pivot points. These can be used with 996 OR 997 GT3 control arms. They removes ALL of the deflection that occurs with the stock rubber bushings. The hard part has been done...installing the monoballs! You can bolt them on with your current shim stack (996 only) or add 10mm's to your 997 shim stack and you will not need to realign the car.
Stock rubber pivot point: $79x4 = $320 Monoball cartridge: $150x4 = $600 Labor to install: 2hours (just to install the bushings, not put them on the car) SELLING FOR = $550 (includes shipping) These will NOT make noise and your setup changes will be more obvious. The car will handle much better and tire wear will be more even do to the lack of rubber deflection on the stock arm. Shock changes (for those of you with adjustable shocks) will be more noticeable from "click to click" http://a3.sphotos.ak.fbcdn.net/hphot...47372586_n.jpg http://a5.sphotos.ak.fbcdn.net/hphot...30959382_n.jpg |
Bump
Sold
