JRZ RS Pro DA Coilovers
Price: $3600
Location (State): CA
I had these on my 2007 GT3, but am going in a different direction so put the stock shocks back on for now. These have about 2000 miles on them.
$3600
Located in SF Bay Area for local pickup or can ship them (buyer pays shipping)
About the RS Pro Line
Taking club sport performance to the next level, the RS Pro has a remote canister with a digressive blow off system. Digressive blow off allows for a stiff compression valving while maintaining smooth response. The result is a damper that provides ultra solid platform with smooth bump compliance. JRZ standard 22mm piston rods maximize flow to the blow off valve response to great chassis control without using a high spring rate. To customize track to track setups and tailor the chassis to the JRZ RS Pro has an extra large adjustment range. Each adjustment is designed to be an even step giving you predictability when making changes.
Features:
• 22mm rod strut, 16mm rod damper
• 12 clicks of compression, 24 clicks of rebound
• Adjustable gas pressure, monotube
• Piston designed for high performance
• Large adjustment range
• Fixed hoses for easy mounting, available quick disconnect fittings
• Remote reservoir canister
Just returned from Hot Rod Power Tour across the midwest at 2.75" to front splitter. I was in a padded CF seat and never received the spinal compression I have in other cars. I can't speak highly enough, nor my 260# passenger...... Kept getting the same question, are you on hydraulics, and disbelief when I answered that we weren't even bottoming out.
Wonder how much to convert to a 996TT application? There's always the "next" build!
