HP gains in GT Speed over GT, explanation?
GT Speed will have 600 HP vs. stock 552. WHY?? Differences with ECU software? Engine size is same bore and stroke and compression. Differences with intake or exhaust side of engine or turbos more boost??
CONTINENTAL GT
DYNAMIC
From Evo car review: Bentley’s head of engineering, Ulrich Eichorn, is quick to kill the not entirely unreasonable layman’s notion that this performance boost was achieved simply by turning the wick up a little on the twin-turbocharged W12 motor. It’s hardly an over-stressed engine after all. But no, instead they took the ‘diligent, in-depth approach’, improving the cooling efficiency and gas flow through the engine, lightening key components such as the conrods, reducing exhaust back pressure with new catalysts, reducing weight with a single-chain camshaft drive and sharpening up the engine management system.
Any direct knowledge appreciated. Thanks mark mburnste@dmc.org
CONTINENTAL GT
DYNAMIC
Engine: 12-cylinder, 6-litre, twin-turbocharged engine
Power: 552bhp / 560PS / 412kW @ 6100rpm
Torque: 650Nm / 479 lb-ft @ 1600rpm
Driveline: Continuous all-wheel drive
Transmission: 6-speed automatic transmission
Performance: Acceleration -
0-60mph in 4.6 seconds
(0-100km/h in 4.8 seconds)
Max. Speed – 198mph / 318km/h
CONTINENTAL GT SPEED
DYNAMIC
Power: 600bhp / 610PS / 449kW @ 6000rpm
Torque: 750Nm / 553 lb-ft @ 1750rpm
0-60mph in 4.3 seconds
(0-100km/h in 4.5 seconds)
Max. Speed – 202mph / 326km/h
DYNAMIC
