Anyone know how to dyno a Bentley GT in 2wd?
Old May 21, 2009 | 11:41 AM
SXN's Avatar
SXN
SXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to behold
My friend is gonna dyno his car on a 2wd dyno.
Is there a fuse I can pull to disengage the awd?
Or do I have to disconnect his driveshaft?
Is this even possible to do?
Thanks in advance guys.
Old May 22, 2009 | 05:50 AM
telum01's Avatar
i'm guessing that it has a 4motion AWD system since it's so similar to a Phaeton. if it's a gen-V Quattro, it can put 100% power to the rear, so i'd imagine it'd be as simple as pulling a fuse. but from what i've seen with a few quick searches and some scanning is that with 4motion, there's a lot more involved. (insert disclaimer here, i've never worked on a VW/Audi/Bentley type car before.) so what i've seen is that you have to remove the transfer case, put in a 2wd flange, and use an adapter plate to close it all up.
is he using a 2wd dyno by choice?
Old May 23, 2009 | 03:50 PM
SXN's Avatar
SXN
We don't have a 4wd dyno locally so we have to use a 2wd dyno.
I still don't know how we're gonna pull this off.
I know on my 996TT I just have to disconnect the driveshaft.
Old May 24, 2009 | 09:42 AM
telum01's Avatar
unfortunately, there are some big differences in AWD setups. take your as an example: with a 996TT you can just pull the driveshaft, but with a 997TT it isn't that simple. on my STi you have to open up the transmission and either weld the diff or put in an adapter. from what i saw while looking for an answer, VW's 4motion requires as much effort as Subaru's to convert to 2WD.
Old May 25, 2009 | 08:20 AM
WOODTSTER's Avatar
Call Todd at EVOMS. (Phoenix, AZ)
They tune and dyno Bentley's all the time.
Oct 2, 2015 02:23 PM
cutty71
Bentley
Sep 28, 2015 06:58 PM
stevenrmusic
Bentley
Sep 27, 2015 06:55 AM
ek1
Bentley
Sep 26, 2015 11:54 PM
