Tire Pressure Monitoring
Not sure but I think the car can display either. Living in the USA I only PSI and those numbers would be flat tires. Be sure ccwboy that you have properly inflated tires and double check them with a good quality tire pressure gauge. I bought a good one especially for this car. If you dive this car at any real speed get it right or die.
Is that a wider pressure difference than the book calls for? I have mine set at F44 and R40 just in case I run a greater speed every now and then. I accept a more stiff ride to be safe at higher speeds and aggressive cornering.
04-28-2022 12:38 AM
RallyBird
10-07-2015 01:20 PM
horsepowerfarm
09-10-2015 06:09 PM
COBB Tuning
09-09-2015 09:13 PM
