front bumper options.
what are the options for upgrading the front bumper?
can the 08+ facelift front bumper fit on the 04-07? or a gt speed front bumper? what are my options with going with oem. and anybody ever swap the front bumper over? |
Any front bumper from a GT or GTC will fit from 04-10. I upgraded my GTC to a speed front bumper and it was plug and play. All components transfer in the exact same position to the new upgraded cover. Be cautious with transfer of the parking sensors as you want them in the same upright location.
Also do an oil change, clean up and pressure wash the intercoolers/ condenser while your in there. You will be shocked at how much debris gets sucked into those areas. These areas become neglected during routine services. A DIY time to shine. |
Originally Posted by phatz
(Post 3719249)
Originally Posted by blackgtc
(Post 3719276)
Side rockers on the GT convertible are different to accommodate the added stiffening. Supersport rear bumper cover is wider and will require slight modification to interchange.
(Post 3719730)
How much does a 09 or 2010 bumper go for?
Used it Varies.. Very hard to find $2500+
Also need grill trim section $500+ Dealer expect to pay 4-5k. |
Hey wedgeduck
How hard is the front bumper to remove as I need to fit something and route wires into cabin. Heard routing wires into cabin is a toughie. Thanks |
Originally Posted by jc_333
(Post 3720403)
Hey wedgeduck
(Post 3720328)
Installing parking sensors! haha
I have a faulty rear parking sensor and it seems you have to remove the rear bumper to install it? The wire for the mid left sensor is clamped down between bumper and frame. Wondering if one can go under bumper to install or need garage to install sucha simple part!? Thanks
Originally Posted by Wedgeduck
(Post 3720721)
Front bumper is easier than the rear. The rear you gotta remove the tail lights. I don't know about rerouting the wires to the cabin. You running radar jammers and detectors huh? You sly dog you.:cool:
(Post 3720748)
I have a faulty rear parking sensor and it seems you have to remove the rear bumper to install it? The wire for the mid left sensor is clamped down between bumper and frame. Wondering if one can go under bumper to install or need garage to install sucha simple part!? Thanks |
will a new flying spur 4 door bumper work? or its different??
(Post 3724518)
