Garage parking - how does everyone do it?
Old May 13, 2013 | 03:18 AM
kensilver's Avatar
kensilver has much to be proud ofkensilver has much to be proud ofkensilver has much to be proud ofkensilver has much to be proud ofkensilver has much to be proud ofkensilver has much to be proud ofkensilver has much to be proud ofkensilver has much to be proud ofkensilver has much to be proud ofkensilver has much to be proud of
I have a standard size double garage and the CGT fits in with about a foot free at the front and the same at the rear before the garage door closes on top of the rear bumper (ouch, done that!)
Now, whenever I look around at other garages in photos, I don't see anyone using parking stops of any kind. Even the super garages with plenty of space have the cars are all neatly lined up in perfect precision with nothing up against the front wheels.
How do I get parked precisely like that without using anything on the floor?
Although both my cars have front sensors, they're not really that reliable to guarantee the exact spacing I need. The warning buzzer never gives the exact distance.
I have used the double bump plastic parking pads, but they moved around even when I bolted them to the floor. I now use plastic triangular chocks over a mat now, but that's just messy too.
I want a clean floor free of everything on it - and easy parking. How do I do that?
Old May 13, 2013 | 04:50 AM
stevenrmusic's Avatar
stevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond repute
Don't have an enclosed garage here, so use two concrete squares on the hardpack (one per front tire) as 'stops'.
Old May 13, 2013 | 08:22 AM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
When you have your car positioned in the garage as you like it, hang a tennis ball from the ceiling-adjusting the length of the string until it just touches the windshield/windscreen, in line with the steering wheel. You then get fore/aft positioning and lateral as well.
Speaking from experience, a tennis ball hurts less than the smaller golf ball when you inadvertently walk into it
It may not be the best/most elegant solution, but it at least keeps the floor clear...
Old May 13, 2013 | 09:04 AM
Ynot's Avatar
Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !
Stick a poster or a picture on the wall, use that as stopping point for your side mirrors, once they aligned, you should be in the same spot every time.
Old May 13, 2013 | 11:09 AM
Dr.Disaster's Avatar
Dr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to all
I have a small soft chair along the front wall and when I get the fast beep I'm there. Other than that I'd make a mark on the wall in front of the car and when it "appears" to meet the hood then stop.
Old May 13, 2013 | 12:40 PM
ssonss1's Avatar
ssonss1 has a spectacular aura aboutssonss1 has a spectacular aura aboutssonss1 has a spectacular aura about
I line the mirror up with a box that's against the wall, or if the other spur is already parked, I line the mirrors up of both cars
Old May 13, 2013 | 12:41 PM
REDNOSEGT's Avatar
REDNOSEGT is infamous around these parts
i reverse park everytime. very small garage, i made a line on the wall and i keep my driver door open almost touching the wall untill i line it up, i make 2 lines, minimum in and maximum in and i put red tape from line to line so i know what my min and max in and out are
Old May 13, 2013 | 04:31 PM
kensilver's Avatar
Of course (slaps forehead), line the mirror up with a mark on the wall. I forgot I did this a few years ago, but after changing a number of cars in quick succession was always worried I'd forget which mark went with which car. This is the obvious answer, thanks all!
Originally Posted by ssonss1
...or if the other spur is already parked, I line the mirrors up of both cars
The thought occurred to buy a matching CGT for this, but something stopped me
@DonL
Unfortunately the tennis ball comes under my definition of 'mess', so this is a no-go.
Old May 13, 2013 | 08:29 PM
fencera's Avatar
fencera is infamous around these partsfencera is infamous around these parts
"Landmarks" on the wall work well. We also sometimes put the cars into reverse and use the camera to see/double check how far in the car is. Make sure your car is in far enough and, assuming it fits in the garage/spot, you're set!
Old May 13, 2013 | 10:30 PM
DAVE W's Avatar
DAVE W is a splendid one to beholdDAVE W is a splendid one to beholdDAVE W is a splendid one to beholdDAVE W is a splendid one to beholdDAVE W is a splendid one to beholdDAVE W is a splendid one to beholdDAVE W is a splendid one to behold
I use a small mark on the floor behind my car that lines up with the red line in the rear camera. I put it in reverse then drive and pull in watching the line to appear. Dead on every time.
Old May 14, 2013 | 04:40 AM
Merdav's Avatar
Merdav is infamous around these parts
Very simple and inexpensive dead accurate every time. Motion sensor and car cover 2 cars. I have 5 garages and have this unit working in every spot:
http://www.ecrater.com/p/10077858/st...id=52211034499
Old May 14, 2013 | 07:01 PM
kensilver's Avatar
I looked at those, but worried about a battery giving up and the car ploughing into the front wall when the sensors were dead. Have you had a power problem yet?
The low tech mirror idea idea seems to most reliable so far.
Old May 14, 2013 | 07:03 PM
kensilver's Avatar
Even though I won't be using that idea - I go in forwards - I'm intrigued by the accuracy. Must be another way to use that for street parking etc.
Old May 14, 2013 | 09:07 PM
SanibelSpeed's Avatar
From: Split my time between Miami, Sanibel & Woodstock, VT
SanibelSpeed has a brilliant futureSanibelSpeed has a brilliant futureSanibelSpeed has a brilliant futureSanibelSpeed has a brilliant futureSanibelSpeed has a brilliant futureSanibelSpeed has a brilliant futureSanibelSpeed has a brilliant futureSanibelSpeed has a brilliant futureSanibelSpeed has a brilliant futureSanibelSpeed has a brilliant futureSanibelSpeed has a brilliant future
My garage is 8' wide so it's a bit tight. It's pretty deep so I have lots of space fore and aft, though. I fold in the mirrors and go in headfirst using dead reckoning. I know when to stop because the satellite radio usually cuts out when I'm in deep enough. I have a landmark on the back wall which I line up with the center of the bonnet and I invariably end up just right. Practice makes perfect. So far, that is...
Old May 15, 2013 | 03:31 AM
Merdav's Avatar
No batteries plugs in to power supply for the garage door opener!
